![]() I'm almost done with my 7/900 series accessory swap on my b230 240. The power steering line where it connects to the rack is the only obstacle I have now. I bought a PTFE hose kit on amazon and just need to connect the other end to the rack. Most of the banjo fittings online will not work as most of them are the same size/shape
![]() No need for a banjo. You can use a a straight fitting with a crush washer.
I’d be cautious about using aluminum fittings there, check the pressure ratings. PS is 1300psi or so. You can also get the fittings at a hydraulic shop. Pretty common fittings, they’ll most likely be steel.
Cult Person. Pissing in your Kool-Aid. Head work: https://forums.turbobricks.com/showthread.php?t=349975 Temp Sender Adapters: https://forums.turbobricks.com/showthread.php?t=348169 |
Benchracer Tribe
![]() I thought black was steel and blue aluminum
"you can't leave your thingy hanging in public... you can get arrested." "What's Arkansas supposed to be, Kansas for pirates?" Forg "I think I can touch the tire. Damn! I can touch the tire! That hurts!" 240Psycho (on the back seat of my 94 Jetta while I was driving to a J/Y) "Use the barbed adapter like what I use to inflate the air camping mattresses and my dates." FTF Engineering i am inspired. i will replace my windsheild... with an intercooler.swedishK Feedback! |
#4 |
![]() Steel will usually be silver colored in hydraulic fittings. I have seen some black coated steel, but it’s not common.
Aluminum fittings are usually blue, blue/red, black, or silver. |
