![]() Howdy y'all
Over the weekend I finally got around to replacing the PCV system on my 91 wagon. The engine has over 300k on it, and was suffering horribly from overpressure. That said on my first test run around the block post install I noticed a huge cloud of smoke, which upon further investigation I noticed ~1/2 qt of oil that seems to have come from either the headgasket or rear main. The car runs fine, doesn't overheat and never leaked from these areas before. The smoke itself was from the oil burning off on the exhaust manifold and downpipe. Is it possible the change in pressure could've pushed some seals over the edge, or is this just an old fashioned case of user error? |
![]() I have had more than 0ne redblock engine push a seal out. Since it is burning off the exhaust manifold your cam seal likely pushed out. A customer of mine had that happen. Her car's PCV box was almost completely plugged when it happened.
#3 | |
![]() Quote:
Click below: Buyer/Seller Feedback My Volvo parts for sale on eBay Volvo parts for sale on forum - Post are regularly updated |
#4 |
Old and boxy but good.
![]() If you don't spend time making sure the oil drain hose in the engine block is clear. You may still be developing excess crank pressure. The most likely seal being pushed out is the cam plug at the back of the head.
Dave, 1982 242 turbo. 338k miles. MVP coilovers and 3" exhaust. Flowed 405 with a V15. Cossie turbine housing with upgraded compressor housing. 90+, IPD remote oil filter. Some other goodness, too. Been lots of fun over 25 years. Restored in 2k. Now ready for a 2nd restoration. 1993 245 Classic, 440k miles, enem V15. IPD bars and chassis braces. Simons sport exhaust from Scandix. sbabbs ezk chip. Been a good road warrior. Genuine Volvo rebuilt leaky M47. ![]() |
#5 |
![]() That makes sense, I did notice some oil on the valve cover.
#6 |
#7 |
![]() That makes sense, I just found the post you made on modding the hose and might give it a shot.
#8 |
![]() Cool, hope that helps you out. Mine was completely clogged so the mod has worked out well. A friend of mine came up with a long wire brush that he uses to clean the drain hose. I haven't tried it on my car but it worked great on his. Busted right though all the crud and his system now passes the glove test.
