Old 01-30-2014, 10:10 AM   #1
volvo 4 life
volvo 4 life's Avatar
Default Will a 1991 240 fuel pump fit my 1979 242?
My main fuel pump stopped working on my car this week, hit it with a hammer and it turns a few times and stops so it's shot. The in tank pump works fine. I have a 1991 244 parts car with a good pump on it, will it fit my car without modification? I would buy a brand new one but I can't find any direct replacement k-jet pumps. My car is a 1979 242 with a turbocharged b21 and lh2.2, so if there's a specific pump recommended that would work best I'm up to suggestions, I just want to fix my car. Thanks
Originally posted by Forg: "How To Properly Seafoam A Saab In One Easy Steps":
Step 1. Push into sea.
Originally Posted by Tenacious Todd View Post
I was hitting the brakes real hard and the grille flew out and I ran it over
Only on a Volvo...
Originally Posted by isaac View Post
A volvo 240 with the front wheels chopped off would be a reliable all wheel drive vehicle.
volvo 4 life is offline   Reply With Quote
Old 01-30-2014, 11:03 AM   #2
cleanflametrap
cleanflametrap's Avatar
No need for a k-jet pump to keep an LH2.2 regulator returning excess to the tank. Your question is just about fit now.
Also, I would encourage you, if you have the means, to take your dead pump apart and see if you can determine whether brush life or commutator life was what ended the pump's life. And see if your hammer taps were enough to crack the permanent magnets. You have an opportunity to learn something and teach us too.
-Art
Old 01-30-2014, 12:03 PM   #3
volvo 4 life
Yeah when I take it off I'll try and disassemble it. For right now I just need to know if the newer style pump will fit the existing lines under the car so I can get this thing back on the road because as of right now it's sitting in my driveway taking up space.
Old 01-30-2014, 12:11 PM   #4
http://www.ipdusa.com/products/6996/...pump-k-jet-200
Philski has one for $65 HERE
Old 01-30-2014, 02:32 PM   #5
volvo 4 life
Thank you. I couldn't find the k-jet pump on ipd when I searched for it under my car's model and year. Are there any differences in how the k-jet pump and lh pump are connected?
Old 01-30-2014, 03:38 PM   #6
Kjets On a Plane
Kjets On a Plane's Avatar
Some replacement pumps for Kjet or LH have ring terminals instead of the original bullets. I make an adapter harness so it still unplugs rather than chopping the car harness.
But originally, they use the same electrical bullets.
Fuel hoses are a little different. You can swap the check valve? IIRC and re-use the k-jet fittings to the accumulator. YMMV on that. IIRC the pump bracket and mix and match from your 91 you ought to be able to do it.
Sometimes brand new is nice.
Bushings may have also worn in the pump from grit on a nearly empty tank/disintegrating sock/dead intank. Verify how the tank looks inside and how well the tank pump works.
How PSI a stock can support?
Always Be Crushing!
Old 01-30-2014, 11:38 PM   #7
planetman
planetman's Avatar
The style of fuel pump for K-jet changes in 1980.
Does your fuel pump look like this Bosch fuel pump for 1979 and earlier K-jet?
Or does your fuel pump look like this Bosch fuel pump for 1980 and later K-jet and LH?
Eric
Torrance, CA 90502
Old 06-22-2014, 10:17 PM   #8
1984brick
1984brick's Avatar
hey guys, I'm currently having the same problem with my 1979 242 GT, is it very hard to make my own connectors if i buy a different pump? how would i go about doing it? thanks
1984brick is offline   Reply With Quote
Old 06-22-2014, 11:17 PM   #9
culberro
culberro's Avatar
The connectors are snip, crimp, heat.
