Old 03-06-2015, 12:46 PM   #1
grnmachine02
Indicating?
grnmachine02's Avatar
Default T5 clutch options (not clutchnet)
So, clutchnet has had my money for a month, and won't return emails or answer phone calls. I've got to start looking for other options as the clutch is the only thing stopping me from putting my car back together.
B230ft, 740 dog dish flywheel, and luk pressure plate. What other options are out there? Anyone had any experience with spec? I hadn't used clutchnet in a while, but i'm disappointed in how far their service has gone downhill.
1990 745t- b230ft, ebay manifold, hy35, Microsquirt, t5 2jz and w58 eventually no engine, and a decent mold collection on the interior.
Rage boner achieved.
grnmachine02 is offline   Reply With Quote
Old 03-06-2015, 01:03 PM   #2
740atl
rb67 life
740atl's Avatar
Look for a local clutch shop to make you something.
Old 03-06-2015, 01:15 PM   #3
TIPSP
Got Boost?
TIPSP's Avatar
http://www.yoshifab.com/store/index....&productId=117
Old 03-06-2015, 01:16 PM   #4
grnmachine02
Indicating?
Originally Posted by TIPSP View Post
I totally forgot about that! Thanks!
Old 03-06-2015, 01:28 PM   #5
gsellstr
gsellstr's Avatar
Or hit up Southbend. Guys there are awesome to deal with, they answer the phone and emails, they ship stuff out when it's ready. Not many shops I've been pleased with, they are one that will see my return business.
FWIW $390 delivered for a beefed up plate (different spring, sachs housing), Kevlar disc, t/o, pilot, and alignment tool, rated for 275ft.lbs.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 03-06-2015, 02:12 PM   #6
Mylesofsmyles
Interesting...I've had nothing but luck with Clutchnet.
Old 03-06-2015, 03:16 PM   #7
grnmachine02
Indicating?
Update: Clutchnet finally called me back (only after I threatened to issue a charge back if they didn't contact me by Monday) Clutch should ship today....we'll see.
Old 03-06-2015, 04:44 PM   #8
Beep beep zip tang
I have used 2) Southbend clutches on my Matrix, good deal on a 320ft./lb clutch. compared to everyone else.
Old 03-06-2015, 05:09 PM   #9
volvo 4 life
volvo 4 life's Avatar
How does that yoshifab disc hold 400hp? Upgraded pressure plate?
Originally posted by Forg: "How To Properly Seafoam A Saab In One Easy Steps":
Step 1. Push into sea.
Originally Posted by Tenacious Todd View Post
I was hitting the brakes real hard and the grille flew out and I ran it over
Only on a Volvo...
Originally Posted by isaac View Post
A volvo 240 with the front wheels chopped off would be a reliable all wheel drive vehicle.
volvo 4 life is offline   Reply With Quote
Old 03-09-2015, 10:12 PM   #10
Slick1
I had the exact same problem with clutchnet. Every time I called them it would be shipping out that week, but it probably didn't ship for a few more months.... It was pricey too and my clutch still slips sometimes in 3rd gear.
Slick1 is offline   Reply With Quote
Old 03-09-2015, 10:43 PM   #11
cosbySweater
cosbySweater's Avatar
Did you check and make sure you don't have to shim the pressure plate?
1995 Porsche 993
2013 VW Passat TDI
Old 03-09-2015, 10:49 PM   #12
badvlvo
Bad for Babies
badvlvo's Avatar
I've never had a problem with Clutchnet. 10-ish clutches now, never a complaint.
Died at age 35
Old 03-10-2015, 10:36 AM   #13
Slick1
There isn't a problem with the clutch fully engaging via the clutch pedal, I can back off the cable adjustment until it can't even be depressed if I wanted to. Is there more going on here than I'm thinking?
Old 03-10-2015, 10:56 AM   #14
Chewy
Chewy's Avatar
Dog DIsh flywheel = 9"
The yoshifab disc (I run one), is for an 8.5" flat flywheel....
These will not play nicely together.
And my gut says the 8.5" disc is an off the shelf ford part.... (SVO?)
Originally Posted by alreadyupsidedown View Post
Just think of K-jet as an extremely complicated mechanical Rube-Goldberg carburetor.
Originally Posted by volvo240skunk37 View Post
Good God son, you're just a pile of fail.
A-A-Ron
Going away: 69 142 "Inga" Build Thread
Had: 80 242 "Elsa" Build Thread
Chewy is offline   Reply With Quote
Old 03-10-2015, 07:55 PM   #15
grnmachine02
Indicating?
My clutch shipped, needed a signature and I was at work. Oi. Apparently the hold up was that I ordered a kevlar lined clutch, and they didn't have the kevlar in stock. I'm ok with that explanation, but a little communication goes a long way.
Edit:// I should add that once I got someone on the phone, they were very helpful and made sure I was taken care of.
