Old 03-12-2015, 04:33 PM   #1
shenkerism
Default What's the largest V8 you've seen in a Volvo?
200-series, specifically.
I'm asking because I may or may not have a 460 lying around not doing anything. I haven't had a chance to measure my own, but according to the intertubes it's 27" wide from manifold to manifold, 34" long. So different manifolds may be required based on how precisely they fit between the towers. The radiator would need to move.... somewhere further forward. Might have to cut a hole out of the hood, and if I did that I'd swap it over to carbs for that look.....
Anyway, I don't have NEARLY the resources to do that... just thinking out loud.
Based on what you've seen, what is the upper limit for engines in the stock bay of a 240? (No mods of the frame/towers/firewall.
Last edited by shenkerism; 03-12-2015 at 04:40 PM.. Reason: Clarified that I'm referring to the 200-series.
shenkerism is offline   Reply With Quote
Old 03-12-2015, 04:42 PM   #2
zdriver123
zdriver123's Avatar
Haven't seen it in a Volvo, but you could get a 500ci Chevy to fit into a stock bay. don't expect to use a hood, and expect to spend a boatload of money.
My money is that you couldn't fit a ford big block into a 200 chassis. If you could, the car would be a nightmare to turn.
zdriver123 is offline   Reply With Quote
Old 03-12-2015, 04:52 PM   #3
shenkerism
Yeah, a myriad of problems pop up when you start thinking about the swap. For instance, the engine weighs about 720 pounds, more than two B23s.
Old 03-12-2015, 04:54 PM   #4
shenkerism
It's really too bad there isn't enough room in the back of a wagon to make a 7.5 liter, mid-engine, rear drive destroyer of worlds/harbinger of the end-times.
Old 03-12-2015, 05:01 PM   #5
benski
Post
Casale V-drive and some uh, generous springs.
Old 03-12-2015, 05:05 PM   #6
volvo 4 life
volvo 4 life's Avatar
Someone did a ford 4.6 DOHC swap, they're very wide engines and it fit. Big block is just so damn heavy though.
Originally posted by Forg: "How To Properly Seafoam A Saab In One Easy Steps":
Step 1. Push into sea.
Originally Posted by Tenacious Todd View Post
I was hitting the brakes real hard and the grille flew out and I ran it over
Only on a Volvo...
Originally Posted by isaac View Post
A volvo 240 with the front wheels chopped off would be a reliable all wheel drive vehicle.
volvo 4 life is offline   Reply With Quote
Old 03-12-2015, 05:49 PM   #7
http://forums.turbobricks.com/showthread.php?t=178398
Old 03-12-2015, 05:57 PM   #8
Ursan
Bored Member
Ursan's Avatar
Someone was thinking of an 8.2 Cadillac.
http://www.turbobricks.com/forums/sh...d.php?t=146888
how psi a stock can support?
I admit I'm stupid...
Old 03-12-2015, 06:12 PM   #9
122power
dude
122power's Avatar
Big block with aluminum heads, intake. Then it wont be so heavy.
Save the Volvo's.
Ring,ring,ring
"Hello"
"Do you work on Volvo ...
*Click - bzzzzzz*
Old 03-12-2015, 06:14 PM   #10
zdriver123
zdriver123's Avatar
Built LS1, even lighter.
Old 03-12-2015, 06:27 PM   #11
shenkerism
Originally Posted by harribert View Post
I was reading the thread, waiting for the post about a broken diff. Didn't take long
Old 03-12-2015, 06:33 PM   #12
zdriver123
zdriver123's Avatar
Depending on how you calculated for swept volume, you could come close to Big block V8 displacement with a rotary.
Old 03-12-2015, 07:11 PM   #13
shenkerism
Liquid Piston Rotary? Their website says it's scalable from 1 HP to 1000HP...
2HP/lb, smaller, no vibration...
I bet a big one sounds cool.
Old 03-14-2015, 03:48 PM   #14
blackbndt
427 SBC = 7.0L
No inner fenders I'm sure you could fit a BBC in there, I put a 454 into an FC RX7 once....worthless to say the least.
blackbndt is offline   Reply With Quote
Old 03-14-2015, 05:14 PM   #15
745 TurboGreasel
745 TurboGreasel's Avatar
nine liter 960
Feedback
Old 03-15-2015, 07:13 PM   #16
gashog
gashog's Avatar
A guy that worked for Eric J. (aka Volvo Dr in Sussex NJ) squeezed a 460 into a 245.
The radiator was out in front of the rad support and no bumper.
A guy down the road from Eric's shop had a 245 drag car with a twin turbo gen1 small block.
Here comes the BOOST!
gashog is offline   Reply With Quote
Old 03-16-2015, 12:33 AM   #17
larry818
larry818's Avatar
I had a 426 Hemi in my '86.
It was a wagon. It was in the back. The B230 didn't mind hauling it around.
larry818 is offline   Reply With Quote
Old 03-16-2015, 12:35 PM   #18
tt460
tt460's Avatar
If a Ford 32-Valve modular will fit, then technically a 460 will fit (width wise a 460 is narrower than a DOHC modular, but the 460 is considerably longer than a modular so you'll run out of room by the radiator). However I'm not really sure why anyone would consider a big block for a street car anymore when you can get more power and nearly the same cubic inches out of a stroked small block. Add to the fact that the 460 was the heaviest production motor built for passenger cars.
I had a twin turbo 460 in a Fairmont for several years. Then I grew up and switched to Ford small block and modular stuff. They're great for towing... With turbos they'll do cool rolling burnouts at 60MPH... Unless you're doing that the allure of the big block fades when you realize it's really just an awkwardly big heavy engine.
Don't forget your transmission options are mostly limited to an equally awkward, heavy C6 unless you invest in custom bell housing and converters.
87 Volvo 745T
lambdatuner.com
tt460 is offline   Reply With Quote
Old 03-16-2015, 03:32 PM   #19
rwturbo
rwturbo's Avatar
Default Big block in a tube chassis 1800 wagon
Awesome car drag only of course. Have pics somewhere.
rwturbo is offline   Reply With Quote
Old 03-16-2015, 05:56 PM   #20
dieselboy
Whooty patrol
dieselboy's Avatar
There's a 240 with a caddy 500 around somewhere isn't there?
'82 242t hy35 @28psi, ebay header, big intercooler, microsquirt ecm, rsi stg2 cam, arp headstuds, tremec tko600, 3" exhaust, 13" brembos, coilovers, saabspoiler, 245/40r17s, lots of yoshifab stuff.
'12 flex ecoboost "kats" car
'93 940 turbo lifted #trophyvo
'08 f350 4x4 v10 cclb
'97 f-350 4x4 offroad toy
'94 4700 dt466 International toterhome build
dieselboy is offline   Reply With Quote
Old 03-18-2015, 11:18 PM   #21
CoconutColin
CoconutColin's Avatar
Originally Posted by larry818 View Post
i had a 426 hemi in my '86.
It was a wagon. It was in the back. The b230 didn't mind hauling it around.
cheeeeeky!!!!!
1986 245 - Daily Driver
1982 245 - 302 CI V8 Air Ride Lowder
1958 PV444 - Student Project
1991 Volvo 244 - 18'' RIP
1981 Volvo 244- 18'' RIP
1982 Volvo 244 - First car. Benz lights, various bumpers, spoilers, porche rivera blue. RIP
CoconutColin is offline   Reply With Quote
Old 03-19-2015, 01:07 PM   #22
shenkerism
Old 03-19-2015, 01:11 PM   #23
badvlvo
Bad for Babies
badvlvo's Avatar
Nice. I had an aluminum block 568ci Chevy in the back of mine for a couple days. So paranoid someone would steal the car for that engine!
Died at age 35
Old 03-19-2015, 02:22 PM   #24
larry818
larry818's Avatar
I had no fear anyone would steal the 426, I had more fear that it would never come out, or that the rear end would ever be the same.
Old 03-20-2015, 02:33 AM   #25
gashog
gashog's Avatar
This reminds me of a detachment to Fallon Nevada.
We were all bragging and swapping top speed trun stories and I asked one of my buddies how fast his HD 883 went.
150mph he claimed
"ask Renny". Renny nodded and said "it was in the back of my truck!".
