Old 02-27-2021, 03:29 PM   #1
volvo 4 life
volvo 4 life's Avatar
Default Fitting ESR 17x8.5 wheels on a 242
I’m looking at buying a set of esr wheels. They’re 17x8.5 with 5x108 bolt pattern and 30mm offset according to the description and I’d like to run them on my 79 242. The car has 2 coils cut off the stock springs in front and I’m going to cut 1 out of the rears in the spring. Is there any possibility of these fitting and if so, what size spacers/adapters would I need? Thanks!! Here’s the link for reference https://www.ebay.com/itm/133661055995
Originally posted by Forg: "How To Properly Seafoam A Saab In One Easy Steps":
Step 1. Push into sea.
Originally Posted by Tenacious Todd View Post
I was hitting the brakes real hard and the grille flew out and I ran it over
Only on a Volvo...
Originally Posted by isaac View Post
A volvo 240 with the front wheels chopped off would be a reliable all wheel drive vehicle.
volvo 4 life is offline   Reply With Quote
Old 02-27-2021, 03:42 PM   #2
https://www.ebay.com/itm/4pc-Hubcent.../192135601432?
Old 02-27-2021, 05:11 PM   #3
volvo 4 life
So 20mm will be enough to clear the strut tower up front and still fit inside the fenders? Any idea what size tire I’d have to run? I would like to use 235/40-17’s if possible, seems like a very common size. Or 225/40-17, not really sure what would be best but I don’t want to stretch the sidewalls and would prefer not to cut/roll the fenders. I’ve tried searching for all of this info but it seems to be really specific depending on the exact wheels and specs of the wheels so it’s hard to know exactly what will work.
Old 02-28-2021, 06:11 PM   #4
volvo 4 life
Anyone have these or wheels with the same specs on their car?
Old 02-28-2021, 08:45 PM   #5
Corey
Corey's Avatar
Lots of info on 240 wheel fitment out there. Look at specs of what others are running, do a little math and you can figure it out. FYI, you will almost certainly need to cut or roll the rear fenders
sig pic
'81 242 turbo
Corey is offline   Reply With Quote
Old 03-02-2021, 09:09 AM   #6
AndrewNance
Amateur hour!
AndrewNance's Avatar
I don't think 225/40/17 exists other than dedicated autox tires. 235/40 isn't very tall and would be my choice. My advice is that if you're going to have to run spacers anyway, you may as well get the wheels in a more common bolt pattern like 114.3 and just adapt them. 5x108 stuff is a hard sell if you decide to get rid of them later.
'67 122 - b230, t5, 8.8
Feedback
AndrewNance is online now   Reply With Quote
Old 03-02-2021, 09:31 AM   #7
volvo 4 life
That’s a good point, always good to think ahead. The 5x114.3 pattern is much more common for the esr wheels too which is also really nice. Looks like I’ll be ordering up a set and some 20mm spacers, I’ll update the thread once I have them installed so anyone else wanting to use them has the info. Thanks!
