holy crap that looks awesome.
how did you prep it? spray method?
After the "bodywork" was done on left front corner I the scuffed entire engine compartment down with a red scotch brite pad and Castrol Super Clean. I sand any nicks, scratches or wear marks smooth with wet 220, then wet 400. Once I was happy with everything I did one final red scotch brite and Castrol Super clean scrub down and blew it dry with compressed air.
Pulled into garage, removed, taped and papered everything. Once I was ready to shoot I wiped it down with a pre-paint safe solvent to make sure I got all the possible grease type stuff off. Mixed the paint and painted it.
I used the cheap Harbor Freight HVLP gun (I've seen it for $9.99-14.99 on sale) with a pressure regulator and a disposable water trap attached to it. I actually did a little research on cheap guns and many professionals have one of these guns as an emergency back-up and they are impressed with it, especially for the price. There is another one that comes with regulator, but they all say to get this one and regulator separately.
Gun:
http://www.harborfreight.com/air-to...ow-pressure-gravity-feed-spray-gun-47016.html
I can't find the regulator or filter online. Mine look just like this:
http://image.classictrucks.com/f/12...aint_gun_painting_tips+using_a_air_filter.jpg
This paint gun stand comes in handy also:
http://www.harborfreight.com/air-tools/air-tool-accessories/gravity-feed-spray-gun-stand-34958.html
Painting:
Several light coats until all areas are covered and one final "gloss" coat.
Paint: The actual paint was only $60 for a quart with hardener and reducer at my local auto paint supply store. It's a cheap urethane paint called Omni?
Took me 1/3rd of the quart to do what you see in the pics. I still need to do the core support and probably hood hinges.
If you have areas that need filler primer, I use the cheap Omni filling primer and the same gun. It's really pretty thick and only costs $35-40.
If you have small bare metal spots it's a good idea to use a self etching primer first. I just buy a spray can of SEM Self Etching Primer and mist a couple light coats on. It doesn't need to cover fully, but it should all be misted everywhere there is bare metal. It's ok if it's still kind of see through.
Questions? Clarifications?
