chopperead
- Feb 21, 2007
- Northants,UK
Hi guys,
So quick query if i may.
So i have just changed to Sams chips, 3 inch exhaust, 3 inch intercooler pipes, 3 inch ebay intercooler, standard MAF into 3 inch alloy pipe, Cosworth T3 turbo.
I havent yet done anything with injectors or Fuel Pressure regulator but is next on my list.
So started for the first time since changing the above and its initially quite hard to get started you can tell that the mixture isnt quite right, the low down rev is very boggy, 2500 revs pretty ok but as soon as it drops it bogs and stalls or if im quick enough it will bog then get back up again. Once warmed up it will idle fairly ok
Is this normal whilst it re learns or should it run better than this ?
Like i said i am planning on changing fueling but was hoping to run as is on low boost for a bit.
