- Nov 19, 2002
- California
Your mom did.
Your mom did.
You will need both ecus along with injectors from an 850 turbo
Great, thank you for following up!
Do the injectors need to be from a turbo 850, or just any 850?
Excellent, thank you. I'll keep a look out for these injectors. Is the 850 the only model that came with orange tops like you're referring to?
Pretty sure any of the fwd/awd 5 cylinder turbo injectors will work fine. 850, S70, any of the XCs, etc. I have more modern white bodied injectors from a newer model. Can?t remember which one, but if you can?t find any they are super cheap for sale on here.
The big bodied orange ones were only on 94/some 95's.
With a redblock, it doesnt matter. None of the 850 injectors have the correct spray pattern for the port but it doesnt really matter.
The closest match would be the 94/95 ones because they have similar opening times, if you care about calibration at all.
