Old 05-30-2022, 12:44 AM   #1
Brick15
Brick15's Avatar
Default MONOBLOCK VERSUS 2-PIECE CALIPERS, answer may surprise you
An interesting read, wondering if anyone agrees or disagrees and why
https://centricparts.com/getmedia/34...LOC_8-2018.pdf
Taken from here dated August 24, 2018
https://centricparts.com/resources/r...ry=Whitepapers
Brick15 is offline   Reply With Quote
Old 05-30-2022, 02:13 AM   #2
Alex Buchka
8 cylinders
Alex Buchka's Avatar
Carroll Smith died in 2003. The dates listed are likely when Centric just re-hashed the writings on their own letterhead after purchasing StopTech.
I wouldn't say there's really anything to disagree with in the paper. The main assertion - that a bolted two piece caliper will be more rigid than a similarly shaped monobloc - is well grounded in first-principles of structural mechanics and is not a matter of opinion.
Alex Buchka is offline   Reply With Quote
Old 05-30-2022, 03:27 PM   #3
It's all about designing for a finished system. You can have well-engineered monoblock calipers and 2 piece calipers... or you can have poorly executed versions of both.
At some point, its also worth noting that the difference in caliper stiffness may be negligible if you are not taking into account the mounting stiffness to the spindle.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 05-30-2022, 04:15 PM   #4
sbabbs
sbabbs's Avatar
We'll dat's just like yur Opinion, man..
1990 745 B230FT Getrag JohnV flywheel 240mm clutch 13c A-cam 3.54 G80 555K
1995 940 White racing wagoon. 13c.
Old 05-30-2022, 04:33 PM   #5
Just to be clear, you are referring to 2-piece calipers as fixed, multi-piston calipers and not sliding/floating ones, correct?
Old 05-30-2022, 05:57 PM   #6
mikep
The MP
mikep's Avatar
I was wondering the same thing. When i think monoblock i envision holes bored all the way through with screw in plugs or something.
Originally Posted by megulon-7 View Post
You Oregon beavers keep your hands off our sweet Cali redwood and we won’t touch your Portland $8 doughnuts.
Old 05-30-2022, 06:04 PM   #7
mikep
The MP
mikep's Avatar
Ok, i read the thing. Although it starts by talking about C-shaped (floating) calipers, the whole archaic thing is about the newfangled cnc-manufactured billet 1-piece 4-piston calipers being unnecessary for a firm pedal, compared with 2-piece (when properly designed).
Old 05-30-2022, 06:04 PM   #8
mikep
The MP
mikep's Avatar
And he mentions the original old-school ones with plugs.
Old 05-30-2022, 10:42 PM   #9
Brick15
Brick15's Avatar
Yes fixed calipers, not the sliding type.
What I got from the article is that no matter the design of the monoblock, the aluminum itself will always be the weak point, hence the testing numbers.
Old 05-30-2022, 11:13 PM   #10
For a given side profile and caliper size, a 2-piece caliper should be stiffer than a monoblock caliper.
Even more so when the caliper is hot, as the stiffness of aluminum (Young’s modulus) varies drastically with temperature. That’s where a 2-piece with a bridge support shines, or a properly designed monoblock
As Ben mentioned, caliper mounting is very critical. Just because something is a radial mount, doesn’t mean it’s better. Just because something is a axial mount, doesn’t mean it’s inferior.
Old 05-31-2022, 10:44 AM   #11
You know whats even stiffer than everything mentioned in the above article?
Factory 240 Girling calipers. You don't get much stiffer than 2 piece bolted iron.
Old 05-31-2022, 12:40 PM   #12
"Opposed piston calipers made from cast iron, in which we have little if any interest here, have
always been two-piece assemblies. The material itself is stiff enough that, always assuming a
basically competent mechanical design, caliper flex is usually not a problem."
It was alluded
Old 05-31-2022, 05:00 PM   #13
mikep
The MP
mikep's Avatar
Quick, someone calculate the total unsprung weight per front corner, with the percentage of change when going from the factory caliper to an RX7, etc. caliper.
Old 06-09-2022, 03:01 PM   #14
DrZiplok
DrZiplok's Avatar
Why is nobody talking about thermal interface material? IMO the biggest advantage of a monobloc caliper is the unimpeded heat flow through the body of the caliper, allowing better utilisation of the caliper's total thermal mass during a braking event. If you just bolt two pieces of Al together you have a substantial thermal barrier at the joint face...
DrZiplok is offline   Reply With Quote
Old 06-09-2022, 03:42 PM   #15
The majority of the heat rejection from a standard caliper is through radiation and convection.
While conductive heat transfer is still a part of the picture, it is a smaller part. Think about the conductive heat flow path of a caliper. The conductive heat transfer has to be removed through the bolted interface of the caliper to the adapter. This area is probably 10-25% of the area at the caliper halves. This then goes into the knuckle through another bolted joint of similar area.
Thermal contact resistance of the split halves ads very little to the total picture of heat transfer/cooling of the caliper.
If you really care about the contact resistance, smear a thin layer of heatsink past on all the interfaces...
But that's just my opinion...
Old 06-09-2022, 11:47 PM   #16
DrZiplok
DrZiplok's Avatar
Yes, yes, but *which* heatsink paste. This is the question!
Old 06-10-2022, 05:12 AM   #17
Swedbrick
Swedbrick's Avatar
The xc70/xc90 calipers I have use a split design to enclose the seal and piston in aluminium. Presumably this also helps cooling.
Volvo 363 - N/A, Speeduino, GSXR ITB's, half-cage, work in progress
