el-barto
- Apr 27, 2003
- Germany,Munich
Hi,
I have a setup with the LH 2.4 and EZK 116 on my B21ET in my Amazon.
Everything runs fine and hot/cold idle is about 800-900 rpm.
But when I once rev over ~5000-6000 idle speed raises to 1500 rpm afterwards.
When I turn the ignition off and on (less than a sec. off) idle speed is at 800-900 again.
All parts are cleanly rebuilt. And I checked for air leaks multiple times.
Signals from throttle flap are correct.
I did not have the speed input of the LH connected yet. (pin 17)
But now I simulate this input using an arduino, giving it 8 signals per drive shaft turn.
I thought this missing input was the reason but I still see raised idle speed after a short high rev.
Do I perhaps reach some kind of limit of the fuel map ?
Any ideas ?
Thank you in advance,
Bart
Any ideas ?
Bart
