![]() Has anyone done testing to see which calipers have more potential. Yes I know to get something truly good I will need to do a true upgrade, but I have Girling on my 765, and bendix on my parts 764, so I want to put the best ones on my main car.
![]() While I don't have comparative performance numbers for those calipers, my experience with maintaining the Bendix was continually frustrating. Best thing I did was swapping to Jumbo brakes from a 93 940. That gave a clearly noticeable braking performance boost, and far better troublefree reliability.
![]() Pretty easy upgrade. The hardest part was figuring out which lines to use and which to plug. Extra bonus: better bearings. Drawback? Slightly higher unsprung weight. Haven't been able to notice or quantify this. |
![]() Join Date: Oct 2004
![]() Also a better pad selection for the Girlings.
RIP Doug Williams "Mr. Doug" 4/15/2009 Pete Fluitman "fivehundred" 7/14/2013 Mick Starkey "TrickMick" 1/10/14 Mark Baldwin "blue850t5" 7/19/18 Nick Fengler "fengler" 8/6/18 Thomas Fritz "stealthfti" 10/11/18 Bob Davi "bob davi" 10/2021 74 144 B20 http://forums.turbobricks.com/showthread.php?t=224983 90 745Ti http://forums.turbobricks.com/showthread.php?t=334698 If you need Superpro bushings PM me for price and availability! |
#4 |
![]() I would go with Girling just based on one bad experience with Bendix brakes.
Years ago I was trying to diagnose a braking issue on our 744. I came to find the caliper bracket for the Bendix brakes had literally warped itself. The new replacement bracket I ordered was noticeably beefier than the one it replaced. That led me to assume this wasn't an isolated issue. |
#5 |
![]() 91+ ‘jumbo’ brakes or retrofit the 302mm P80 cop duty brakes (been done).
Install 95 (only year we got them in the USA I forget?) 940 brake booster & pedal bracket? Nice upgrade tho idk if there’s an easy answer there for youse 7/9 guise with manual trans pedal setups?…never crossed that bridge… Idk what else to do recombining the Volvo junkpile on the TB-ch33p, most 7/9 brakes suuck for pedal feel/modulation compared to 240 or 164 setup w/fixed calipers on the 140 even… …been a while since I had a 7/9 & did the wheel bearing, brake & booster easy bolt-on upgrades in those… As BNE sez of 7/9s; ‘accordion bumpers; with brakes this bad, you’re gonna need em!’ There are also the very rare early girling alloy reinforced finned calipers for 700s…idk if you can get rotors worth a darn for them, but they have a little better pedal feel & fit under 14” alloys where clearance is tight if that matters?
How PSI a stock can support? Always Be Crushing! Last edited by Kjets On a Plane; 01-16-2022 at 10:39 PM.. |
#6 |
![]() Another variation is 850 calipers, 302mm brackets, 305mm rotors from P2 V70 and longer bolts with a ~6mm spacer.
740 with b21, holset and vems - 352whp |
#7 |
unbalanced chemical
![]() Join Date: Jun 2002
![]() My vote is for the 850 brakes, for the cost and effort of doing it you can do it will all new parts for Sub $400 or less and the impovement is huge. While the late model Jumbo brakes are nice the 850 stuff is even better and barely any extra effort to make work. Ditch all of the two piston and dual hose options of the old 7 series and just go with a nice bolt on soluion. I had the dual hose option on my 1991 744T with dual piston and I ditched that for Wilwoods, both of my 945T wagons have the 850 brakes.
https://forums.turbobricks.com/showthread.php?t=344357 |
#8 |
![]() So my final question with the upgrade, is will my 15" rims still work for the 850 upgrade"
#9 |
![]() Join Date: Jul 2002
![]() 302mm rotor option required a 16" wheel. If you use the 280mm rotor setup, you can use a 15" wheel.
Id avoid the 305 vs the 302. They are super heavy.
#10 |
![]() ^This.
Tho I'm ~99% that P80 cop cars use 15" steelies w/factory junk-drawer common-enough/mass produced P80 302mm brakes, but IDK about 7/9 swaps w/different hubs/offset wheels or late MK2 95+ 960/S/V90 swaps (tho those use FWD offset wheels, obviously)? IDK if those steels are unique to that application in Scandinavia or different from ours? Steels are obviously thinner than alloys for the same strength. 280 is the standard P80 rotor, yeah? What are the 7/9 sizes / ways to make those brakes or cars suck less or be less of a pig w/slow steering & numb terrible no-modulation brakes to drive? 15" wheels are kinda important for uh...those of us that um...do John Lane sorts of things with our cars (on a smaller scale) & are TB-¢h33p-Budget™ ![]() Last edited by Kjets On a Plane; 01-24-2022 at 12:20 AM.. |
#11 |
my other ride is a exmark
![]() Join Date: Jan 2003
![]() has anyone done the 320mm oem setup instead of the 302mm on a 7/9?
87 765 GS Wagon LT4/T56 90 740 Turbo M46 90 780 Turbo 93 940 Turbo Wagon 99 SL500 AMG Sport 08 Corvette JSB LS3 6 speed 08 Escalade AWD- wifes daily 15 Ram CCSB Hemi 4wd Life is short, so live it! You are only old when your dreams are replaced by regrets. |
#12 | |
Benchracer Tribe
![]() Quote:
Incidentally, I also have been wondering about the 95+ 960/S/V90 swaps. Someone here mentioned doing it and that it involved welding new bits to the frame. But, it would open the wheels option bin without requiring spacers.
"you can't leave your thingy hanging in public... you can get arrested." "What's Arkansas supposed to be, Kansas for pirates?" Forg "I think I can touch the tire. Damn! I can touch the tire! That hurts!" 240Psycho (on the back seat of my 94 Jetta while I was driving to a J/Y) "Use the barbed adapter like what I use to inflate the air camping mattresses and my dates." FTF Engineering i am inspired. i will replace my windsheild... with an intercooler.swedishK Feedback! |
#13 |
Benchracer Tribe
![]() So, would any, say, v70 brake caliper + bracket work with a 280mm rotor in a 700/900?
