Old 01-30-2022, 10:34 AM   #1
mr brick driver
Default What tire size for Galaxy wheels on IPD lowered 242 Turbo.
Thanks.
1992 745 TI+ anti slip differential, 1983 242 DL, 1990 780 Bertone, 1983 242 Group A X 2
mr brick driver is offline   Reply With Quote
Old 01-30-2022, 10:45 AM   #2
HiSPL
Fanking Champion 1993
HiSPL's Avatar
https://tiresize.com/calculator/
Click the "Comparison" tab on the left. Then you can put in the stock size and compare it to whatever you are thinking about getting. This way you can see how the overall circiumference will affect your speedo.
Other than that you just search around to see what size tires people have managed to fit, how much fender rolling was required, and if they used spacers or not....
Beets taste like buttfeet.
Originally Posted by 240 240 View Post
water-cooled VW owners can't even tell you the flavor of Cheetos they ate last night.
Originally Posted by Lando
Tinnitus and hearing loss? Sounds like your ears could tolerate some Bose 901s!
96 960 (rotted)
88 244
06 XC90 V8
03 V70(crashed)
92 745 Turbo
Old 01-30-2022, 11:15 AM   #3
JE Jr
JE Jr's Avatar
205/55R16 is the standard suggested size. When it comes to looks, I also think this looks the best with almost horisontal side walls.
White car: --744 GLE ´88-- Polishing object
Black car: --S80 V8 ´07-- Daily driver
www.garaget.org/JE_Jr
JE Jr is offline   Reply With Quote
Old 01-30-2022, 11:20 AM   #4
HiSPL
HiSPL's Avatar
205/50/16 keeps the standard circumference almost perfectly.
205/55/16 is 2.9% larger than stock, which means a reduction in gearing, and a 2 mph error on the speedo at 70.
I know it's not much, but these things add up. You wouldn't want to +T your car just to throw away 2.9% of that new found torque by making the wrong choice in tire size.
Old 01-31-2022, 12:20 AM   #5
Kjets On a Plane
Kjets On a Plane's Avatar
205-55-16 is the 'summer' size.
Fits/works like factory, used to be common enough as the optional size on WRX, Impreza, Accord, Camry Passat etc 'sportier' models, same with 2/7/9 Volvo up to ~15 years ago or as the base model on Matrix/Vibe on steelies now .
The 50s drive all darty/don't protect the rim/no advantage. Wider & they're all flubbery & don't break-away predictably & are more prone to rub or hydroplane.
2.9%. From what? 185-70-14 or 195-60-15 ski-dan tire size?
Isn't that within brand & rolling radius variation w/different pressure in different temps (unless you've got nitrogen/don't have leaky tires or top-up or adjust with air?).
How PSI a stock can support?
Always Be Crushing!
Old 01-31-2022, 04:00 PM   #6
205 55 16 would be my choice.
biggest issue is does the tire compound you want come in that size?
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 01-31-2022, 08:03 PM   #7
122power
dude
122power's Avatar
205 55 r16 woop.
Or 225 50 16 if you wanna run rs4's.
Save the Volvo's.
Ring,ring,ring
"Hello"
"Do you work on Volvo ...
*Click - bzzzzzz*
Old 01-31-2022, 08:17 PM   #8
2manyturbos
He doesn’t even know what RS4s are. A high mileage Michelin tire would be right up his alley.
