![]() non abs 240s pn 1228738
https://www.skandix.de/en/spare-part...4-bar/1014313/ I have asked around for consensus whether or not these parts fail due to exterior rust or interior clogged valves from dirty fluid with debris...got different responses Since they are no longer made, I am curious what TB owners are going to do? Install used ones? They are 34 bar...are people going to run adjustable rear proportioning valves from summit racing or something? (getting the exact pressure right by self adjusting seems impossible) You can rarely find them nos, but they cost more than some cars for 2 of them: https://www.ebay.com/itm/36348287697...oAAOSww3Fepjzf |
![]() You can find new ones. Scandcar lists them for a nose bleed price. The earlier valves as used on the 140 could be taken apart (4 bolt flange held the top hat on) and you can buy rebuild kits for them. The top hat on the 2 series appears to be crimped on so clearly not intended to be serviced. If you did pry off the top hat you would have the hassle of resetting the spring which is perhaps why they do not appear to list rebuild kits.
I pulled the valves off my 1971 142. Put plugs in the ports and sandblasted the outside clean and then disassembled and cleaned the internals. Didn't use a rebuild kit. Made sure not to touch the top hat adjusting screw. Painted the outside with Eastwood extreme chassis black and stuck them back on the car with new brake lines. They work - as far as I know. Push comes to shove you can delete them and install a bulkhead fitting for the flex to hard line connection. Put in a proportioning valve if you think its necessary. You could also find a pair from a salvage 140. At least those a rebuildable. |
#3 | |
- Stock PSI Or Bust -
![]() Generally speaking they're only bad on cars that have sat unused for some time.
![]() See above. |
#4 |
![]() Wait until a 91 pops up in the junkyard and pull the octopus from that, has no sensor like the other years and instead uses a sensor on brake fluid reservoir, you don’t need a light on your dash to tell you that you’ve lost brake pressure. The 91 octopus will never leak
Feedback |
#5 | |
![]() Quote:
#6 |
#7 |
#8 |
#9 | |
![]() Quote:
If they're not you have 30 days to return them for another part or a credit slip for another pull at the JY slot machine whenever you choose to use it. Unless you're being silly and expecting any kind of a guarantee with 30+ year old car parts, NOS or otherwise. ![]() |
#10 | |
![]() Quote:
Live in Medellín, Colombia. Volvos here were owned by cartel members here in the 80s, they were luxury cars and there are not many of them. |
#11 | |
![]() Quote:
EX: It can be sitting on a wet shelf for 30+ years and have shelf wear / be rusty or have been stored in a hot attic and have dried out seals & O rings. |
#12 |
#13 |
Salaminizer
![]() I just replaced them with a pair of SS front brake lines. Direct replacement, but not everyone is going to be comfortable with this.
Feedback thread https://forums.tbforums.com/showthread.php?t=144924 1978 242, 5.3 L33 1979 242, MS, R brakes 2006 V50 T5 AWD @ 17 PSI |
#14 |
#15 |
Salaminizer
![]() Ya it was on my R brake swap.
#16 |
![]() I recently had a pair on an 84 turbo that wouldn't allow any brake flow at all. Couldn't find replacements so I blasted them with brake clean and compressed air and they regained flow. not sure if theres a diaphragm or spring in piston in there so I'm not sure if it was a good idea, but it worked.
Feedback thread 78 242 DL clean daily 80 244 rescued retired autox car 83 245T just for fun |
#17 | |
![]() Quote:
![]() Probably not the best idea to introduce petrochemicals into the braking system, but carry on... ![]() And yes it's a spring loaded rising rate joker valve. |
#18 |
![]() are those proportioning valves specific to the car? If not why not pull/get/install/use one from a similar RWD car or pickup truck ?
#19 |
![]() you would have to find ones with the same fittings and pressure. If anybody did here there would already be a swap solution to a part still being produced...
#20 |
![]() I’ve seen people replace them with an octopus block with the extra ports blocked but then you’ll have a little more brake pressure in the rear than usual, can be done if you’ve upgraded front brakes
#21 | |
![]() Quote:
#22 |
Turbo LS ****poster
![]() Well... that's interesting. Is it really that simple to delete the bias valve? Which front lines? ABS or Non ABS car front line? Any brand you like?
