![]() Hi all,
I recently replaced my motor mounts and trans mount on my 91 244 with the automatic trans. Reason for the repair was the normal trans mount giveaways, vibrations when idling and on startup. I did the motor mounts a few weeks ago, moderate improvement but when I changed the trans mount this past weekend, a whole new collection of vibrations appeared. It feels like they are running through the chassis, but appear on acceleration and deceleration, as well as when revving the engine in neutral above 1500-2000 RPM. Braking doesn't seem to affect them. My only thought so far is that the stiffer mount is now transmitting vibrations to the subframe that holds the transmission, but if that's the case then I have some serious issues I might need to look into... Any help is appreciated |
![]() Driveshaft u-joints, center bearing also.
Pete |
board member
![]() torque rod bushings ?
Desperate need of elf assistant for interior work - Cash/Beer option $ Feedback thread: http://forums.turbobricks.com/showthread.php?t=323689 |
#4 |
![]() Join Date: Jul 2002
#5 |
![]() I should add that the vibrations still happen in neutral. I think it may be the exhaust moving around, it was replaced at some point earlier in the vehicles life
#6 | |
board member
![]() Quote:
It might be something as simple as one of the rubber hangers slipped off, or maybe a cracked pipe. ![]() |
#7 |
mostly lurking
![]() The first clues (vibration started immediately after replaced parts) strongly suggests driveshaft alignment issues. But then you said it vibrates in neutral also.
I'm wondering if you have multiple problems. |
