Old 02-11-2020, 11:13 AM   #1
swedefiend
swedefiend's Avatar
Default 2007 S60, no heat.
Engine has plenty of heat. No real heat is coming out of the dash vents.
Climate control fault?
Old 02-11-2020, 11:37 AM   #2
Beep beep zip tang
Check your coolant level
Old 02-11-2020, 12:23 PM   #3
swedefiend
swedefiend's Avatar
Ya. I did that first
Old 02-14-2020, 01:07 PM   #4
swedefiend
swedefiend's Avatar
Inlet temp on heater core was ~140° and the outlet was ~100° when checking with a non-contact thermometer under the hood (at the firewall)this morning.
Looks like the heater core must be clogged
Old 02-14-2020, 03:01 PM   #5
kampman
dunning-krugersquirt
Do you have access to VIDA? Might be a blend door issue.
1984 245T
2006 V50 T5M
Feedback Thread
Old 02-14-2020, 03:08 PM   #6
swedefiend
swedefiend's Avatar
No. Not yet.
On the blend door issue - I did think about taking the blend door motor loose and actuating the door by hand.
Old 03-05-2020, 12:41 AM   #7
swedefiend
swedefiend's Avatar
Installed new heater core. Problem solved. Now I can actually start driving this car
Old 03-05-2020, 01:13 AM   #8
Nice. Sometimes a backflush will do the trick. Certain late model Camaros have a filter/screen for the heater core inlet that clogs up and will cause a no-heat concern.
Old 03-05-2020, 01:29 AM   #9
swedefiend
swedefiend's Avatar
This is what I shook out of the old heater core. The old part had the factory date stamp sticker in place and the o-rings were brittle, so it was time... no matter what.
On a side note, this thing is like 100 times easier to swap out than any earlier Volvo models. I'd like to thank the engineer that managed to pull that off, LOL.
