Elliotb520
- Oct 23, 2020
- Chicago IL
I?ve just recently purchased a 93 240, and it?s been great besides the fact that I can?t get it to stop leaking coolant. It first sprung a leak from the coolant bypass line that goes from the water pump to the heater core and bolts up to the exhaust side of the block. I cut out the leaky section and replaced it with a rubber hose temporarily until the new part came in. That was holding fine, however it started to leak from where the line met the water pump, but by that time the new lime had arrived, so I put that in. However, that started leaking too from the same place, where it connects to the water pump. I tried to find an OEM o-ring, but i only found one part number and it was wayyy too big, so I used a universal o-ring that fit perfectly. This didn?t work however, as it is still leaking from the same spot. Anybody know what I need to do or what o-ring to buy to get it to stop leaking from here??
