Old 01-23-2013, 02:00 AM   #1
thelostartof
unbalanced chemical
thelostartof's Avatar
Default Regina to LH 2.4 Swap
Ok so I just spent some time looking over the wiring diagrams and as far as I can tell the only thing really different about the two is the wiring for the drivers side fender (MAP and Ign coil/powerstage for regina vs AMM/powerstage for LH (well coil wiring would go to other side). Both EZK and REX seem to use the same pins to go from Fuel->Ign and back.
Besides that everything else maps out to the same pins on each ECU. Does anyone happen to have both ECU's or wiring plugs that they can compare? I will if/when I find time to check out what I have stashed in the shed. I mean even the color's match for what pin they come out of the ECU. A rough look tells me I can just wire the MAP wiring to an AMM plug along with extend the Ign Coil wiring and then wire up and power stage. Once all of that is done besides swapping flex plate in my theory it should work. Since I already need to ditch the AW71L as it is slipping and has a converter that works when it wants to I have no problem putting an LH flexplate in there when I put in this late model AW71 in it.
Has anyone else done this?
Since my 'project' 1991 740 n/a (LH 2.4) is being sold to a friend that needs a car I need to rework my plans back to converting my regina car to LH so I can +T and enjoy it a bit more.
So yea there is my odd thinking for tonight, I will see if I can post the wiring I am looking at and ya'll can tell me how off I am.
thelostartof is offline   Reply With Quote
Old 01-23-2013, 12:57 PM   #2
Stiggy Pop
Stiggy Pop's Avatar
I bought a '93 regina 940 on Sunday that I am considering +T'ing and swapping to 2.4. I'm going to be stripping down my wrecked 91 940t this weekend so I could be able to take a look at ecu's/connectors on both.
my regina car has a block mounted dist., is that typical?
Old 01-23-2013, 01:01 PM   #3
thelostartof
unbalanced chemical
Regina cars can have block mount or head mount. I have owned both setups.
Old 01-23-2013, 01:12 PM   #4
CaffeineSam
Seriously ?
Could we swap in a head mounted distributor from a LH car and call it a day ?
CaffeineSam is offline   Reply With Quote
Old 01-23-2013, 01:24 PM   #5
Originally Posted by CaffeineSam View Post
Seriously ?
Yes, and no. The Regina cars that came with the block mount distributor came that way because Volvo was using up the left over 240 engines. That would likely mean they have a non-slotted cam installed in them. I have never checked whether they do or not. Obviously, if they have the slot, or, if you swap the cam for one with the slot, you can change over to a head mount distributor.
Old 01-23-2013, 01:26 PM   #6
The main reason I just traded the Regina car for an LH one was because I am too lazy to swap trannies and their respective flexplates
Old 01-23-2013, 01:33 PM   #7
Kjets On a Plane
Kjets On a Plane's Avatar
^this.
Had several 1993 Reginas with a block mount dist. Some had slotted cams, some did not when I had them apart to check them out, adjust valves or do a headgasket.
The Regina does have some nasty intermittent bugs and that stupid coil (can be swapped for lh parts), but late model Regina cars 92-93+ are pretty reliable. As good or better on fuel Econ than the lh ones. Block mount dist real nice. Head mount is bean counter, annoying, leaky, costly, and idiotic.
+T a 7 series? People give away turbo ones, relatively abundantly.
How PSI a stock can support?
Always Be Crushing!
Old 01-23-2013, 01:39 PM   #8
thelostartof
unbalanced chemical
My reason for doing it is easier to +t.
Swapping the dizzy location does nothing for lh, lh needs the proper rpm wheel on the crank/ flex plate. So my plan is to redo wiring and swap flex plate when I am swapping transmissions. I can test the car without the trans hooked up so if it doesn't work quick and easy to put the Regina stuff back on.
Now to make sense of the last little bit of wiring and then find a weekend to do it.
Old 01-23-2013, 01:49 PM   #9
CaffeineSam
Yeah well my cam is a K slotted for a LH 2.2 engine so I guess I would be good. The original cam was non-slotted though.
What would you plug the distributor with for a test run though, that's another question altogether...
Sorry for derailing the thread OP.
Old 01-23-2013, 01:55 PM   #10
CaffeineSam
Originally Posted by 945ti View Post
(...) that stupid coil (can be swapped for lh parts).
Come again ? I'm interested...
Plug in a power stage and a LH coil ?
Doesn't LH need a hall sensor signal ?
Old 01-23-2013, 01:58 PM   #11
thelostartof
unbalanced chemical
Yes that is what the flex plate / flywheel does n An lh 2.4 car. That is why there is an rpm sensor on the back of engine.
The lh2.4 distributors do not have the hall sensor in them like lh 2.2.
Old 01-23-2013, 02:05 PM   #12
CaffeineSam
Ah ! A pretty good idea...
Old 01-23-2013, 02:28 PM   #13
Kjets On a Plane
My reason
the right way would be to repair it so it is a clean na car and sell it to someone that just needs a car and buy a 7series turbo. That might make rational sense in the global 2012 economy, which is not the tb way.
The head mount dist would allow one to use stock coil and ignition wire set. Not that there is really any reference window for "right" here and it would not make any meaningful difference as far as crank angle sensing or spark triggering or distribution really.
The again a 7 series +T...yeah...not going to touch that...yikes.
Old 01-23-2013, 03:07 PM   #14
thelostartof
unbalanced chemical
My 944 has a restored salvage title, ipd sways, near perfect grey/cloth interior, ecode headlights, s90 tails, less than two year old heater core i installed, new brakes and bushings and $400 worth of properly tinted windows. The only real flaw is the paint is coming apart and the transmission is in need of replacement one of these years as the lockup works when it wants to. Never mind the custom 4-2-1 header and full new exhaust I built for it along with the silicone cooling hoses and vac lines along with strut brace and under chassis brace. Never mind the new tires and wheel spacers with 850r wheels.
How much do you think your normal person would pay for that and what would be the cost to replace all of that plus find another car in as nice of shape as mine.
The rational thing to do is when swapping the transmission to swap the flex plate and re route maybe 7 wires to make the car lh 2.4 so I can easily turbo it with the custom manifold I am planning on building. As it will be the least amount of effort, time and money spent to have a 93+ turbo car vs buying one with leather or tan interior and swapping everything over or having to buy all of those parts new and install.
Unless 93+ grey/cloth interior turbo cars with all of those upgraded and new parts grow on trees in your area. Because if they do I would gladly trade mine for one from there.
Old 01-23-2013, 08:02 PM   #15
aaron740gl
aaron740gl's Avatar
I swapped from regina to lh 2.4. I ended up swappin the whole harness whivh was a big mistake. It became a nitemare of wiring diagrams and a bunch of "wtf". In the end i finally got it. Ended up swapping pins in the big bulkhead connectors on each side. I should have just swapped over the plugs like you plan on doing. Probably alot easier. I considered it, but got confused about some of the wires. Overall i got it done, and it runs good. Once i figured it all out, it sarted and ran, right off the rip, i installed B cam, swapped to block mount dizzy that has the vacuum adv. on there. It advances on its own and retards in boost and the ecu doesnt have a clue, it thinks its running perfect.
91' 744se with some stuff done to it
aaron740gl is offline   Reply With Quote
Old 01-23-2013, 08:10 PM   #16
boostabear
Watching this as my DD is a Regina 745, that runs great for now, but if something happens I wouldn't mind swapping it to LH2.4 and a simple +t.
boostabear is offline   Reply With Quote
Old 01-23-2013, 08:37 PM   #17
aaron740gl
aaron740gl's Avatar
I know someone here on tb +t'd regina. Maybe more than one person i dont know. I think there is another guy in arizona that has had good luck with boosting regina. I swapped to lh because nobody know much about regina.. Im sure with supporting mods one can make good power with regina, of course a wideband should be the first investment.
Old 01-23-2013, 09:23 PM   #18
CaffeineSam
500dollar740ti did it for pennies using the cold start injector.
740volvo allegedly pushed the enveloppe and ran up to 260 hp with a VAFC module and bigger injectors.
I'm going to try with a SMT-6, slightly bigger injectors and more crap.
Old 01-23-2013, 09:39 PM   #19
LWCook
^this.
In my experience, Regina absolutely has better fuel economy. I can back that up with data from 2 LH and 2 Regina cars. Regina ain't smart, but sometimes stupid plows ahead and gets the job done better.
LWCook is offline   Reply With Quote
Old 01-23-2013, 10:56 PM   #20
thelostartof
unbalanced chemical
I just checked and LH and Regina use the same plugs, I need to validate the pinout and after that it sounds like my idea of just rewiring the Map to a AMM plug and then REX coil wires into power stage and coil, and with a proper LH flexplate it will be LH.
Motivation found.
Old 01-23-2013, 11:53 PM   #21
lookforjoe
Making Volvo Parts Fit
lookforjoe's Avatar
Sounds like a solid plan. Regina blows. In our northeast climate, they had more problems than any other EMS. That coil setup is complete crap. The shop I do some work for has at least one customer that is determined to keep his Regina wagon, converting to 2.4 makes the most sense, if a tranny job or rear main is also upcoming....
Old 01-24-2013, 12:09 AM   #22
Lord_Athlon
300+ Clurb
Lord_Athlon's Avatar
lmk if yoou want a hand
Originally Posted by RvolvoR View Post
simple...just throw the redblock in the trash and install, well, almost anything modern
Yet Asher here went with...
Old 01-24-2013, 12:48 AM   #23
boosted12a
weapon of mass detonation
boosted12a's Avatar
as a regina owner, i must say thnks! ive been kicking around the idea myself and trying to decide to keep my 940 or not. no +t here but was planning a worked head, headder along with the other stuff ive done. to get the most bang out of the parts i figure regina was gonna be a problem. plus for 2.4, the o2 sensor can be found for 39$
91 940 SE, 119K, GOLD
03 540i M sport 6 gears of go! 200k, White
05 S80 2.5T, RED
09 XC70 3.2L, BLUE
10 335xi, (fun has a price), black
17 expedition El, (short bus), black
85 RX-7 GSL SE(efi'ed), BLACK
76 Suzuki RE5, BLACK
boosted12a is offline   Reply With Quote
Old 01-24-2013, 12:59 AM   #24
Kjets On a Plane
I dunno shoot...got a 90 744ti m46 for 2400 with paperwork to new, braces, bars, new tires, solid engine no slap or leak down, 2.5" 2 straight thrrough muffler stainless exhaust system.
Maintained it with new used jy parts. A/c worked at the time. Needed a little a/c work to keep going.
Free car. Deals pop up up here and automatic ones are a dome a dozen even fixed up. Can't sell a perfect sedan for more than about 2000 hardly, maybe a skosh more to the right person with desire for a nice one. 7 series are so worthless though and he motor won't quit that people who have them got them for free and just get cheaper post purchase.
Old 01-24-2013, 11:29 AM   #25
Stiggy Pop
Stiggy Pop's Avatar
Who cares? Some people have have good cars that happen to be Regina and LH parts on hand or readily available. The thread is about regina>LH conversion not why you think it's easier to buy a T car.
I bought a very nice '93 940 NA last week because there are no clean 945T's anywhere around here.
so:
Clean, original 945 - $1300
+T/LH parts - Free.99
That's a lot less than $2400 and I'll take a '93 940 over a '90 740 any day.
