Old 03-30-2016, 07:13 AM   #1
sspony
sspony's Avatar
Default Help! 140/122 wagon dimensions
So I'm planning to make a rather long trip to pick up two new projects. A 66' 122 wagon and a 70' 145 wagon. I have access to a 22' tilt deck trailer and from what I've gathered it's going to be very close dimensionally to load both cars onto it. I would greatly appreciate it if someone could provide me with the dimensions shown in the sketch below. It's close enough that I can't count on Google for this one haha
Many thanks in advance!
Potential, potential, potential....
65' 122s (weekend cruiser) http://forums.turbobricks.com/showthread.php?t=308197
67' 122s (Rallyx racer)
82' 242 dl
83' 242 glt (v8 turbo swap project)
sspony is offline   Reply With Quote
Old 03-30-2016, 12:21 PM   #2
http://www.k-jet.org/files/greenbook..._0_general.pdf
how psi stock cna sprout?
Old 03-30-2016, 12:27 PM   #3
The Librarian
http://volvo1800pictures.com/bros/55....000%20USA.pdf
Old 03-30-2016, 04:13 PM   #4
sspony
sspony's Avatar
I appreciate the info guys! That's half the puzzle. Now I just need to know the front and rear overhangs for each car. Overall length and wheelbase are published but I don't believe those other dimensions are.
Old 03-30-2016, 11:11 PM   #5
sspony
sspony's Avatar
Hoping someone has a tape measure and these cars...
Old 03-31-2016, 08:47 AM   #6
Bobbyz
I've got a tape measure and a 66 wagon. I'll get some numbers for you today. Unless my plans change.
Bobbyz is offline   Reply With Quote
Old 03-31-2016, 11:36 AM   #7
Bobbyz
Ok I see I forgot to measure between the wheels.
Overall 176" (14' 8") between the bumper horns.
26" center front wheel to bumper horns.
47" center rear wheel to bumper horns.
All measurements taken with a 10 year old girl holding one end of the tape ! But I think she did pretty well.
I believe the wheel base is the same on all the 122s so that should be online. My plans just changed with the arrival of house guests. Had a feeling but no official confirmation.
Old 03-31-2016, 01:00 PM   #8
sspony
sspony's Avatar
Great information! Thanks for taking a few minutes to check. Much appreciated!
Now I just need the 145.
Old 03-31-2016, 01:52 PM   #9
Jesse B
Fine Modern Gentleman
Jesse B's Avatar
I have a '69 145. Do you not care about the bumpers?
'73 1800ES, now converted to m41!
'95 944
'95 945
'96 855T, Autumn Gold, now converted to m56!
'11 XC70, T6
Jesse B is offline   Reply With Quote
Old 03-31-2016, 02:18 PM   #10
sspony
sspony's Avatar
Well the 145 I'm looking at is missing it's front bumper so idk haha. So no on the front, yes on the back?
Old 03-31-2016, 02:21 PM   #11
Jesse B
Jesse B's Avatar
K. Will try to remember to do this tonight.
Old 03-31-2016, 05:05 PM   #12
Jesse B
Jesse B's Avatar
I measured:
-Front (without bumper) ~20"
-Rear (with bumper) ~48"
Old 03-31-2016, 05:08 PM   #13
alschnertz
Enough already!
alschnertz's Avatar
My '70 145:
29"+/- front overhang including bumper. 3" less without bumper;
49"+/- rear overhang including bumper.
Old 03-31-2016, 08:35 PM   #14
Jesse B
Jesse B's Avatar
Originally Posted by alschnertz View Post
My '70 145:
This is probably more accurate. I think my front wheel might have been turned in a bit.
Old 03-31-2016, 10:40 PM   #15
sspony
sspony's Avatar
Thanks guys! I'll post what I come up with for a shipping arrangement.
Old 04-01-2016, 08:56 AM   #16
Jesse B
Jesse B's Avatar
You're welcome! Hope you can take them both home.
Old 04-01-2016, 10:13 AM   #17
sspony
sspony's Avatar
Well it looks like the only way to get them both on is to put the rear tires of the 122 up on the front rail of the trailer. This is a rough model. Only critical dimensions are correct. So the car bodies aren't even close. The hitch is not modeled either. However, I will likely use an extension to keep the car back away from the tailgate.
Old 04-01-2016, 05:24 PM   #18
alschnertz
Enough already!
alschnertz's Avatar
How long is this "rather long trip'?
Maybe it would be better to get a bigger (properly sized) trailer.
I avoid trailering things that are iffy. In your case, iffy appears to be close to falling off.
It's just too stressful - on my brain, not the trailer.
Old 04-01-2016, 07:57 PM   #19
Bobbyz
Weight distribution could be an issue with a bumper pull. You want to keep the weight to the front of the trailer otherwise they get real squirrely. Going down hills they can start dancing around on you.
More than one old car went from project to scrap iron that way.
Just be real careful !
Old 04-01-2016, 09:57 PM   #20
sspony
sspony's Avatar
Fortunately this is a rather light load. Only 5k-ish or so. The trailer is typically used for equipment and such. 10-12k rated.
However I do share your concerns and the name of the game would air down the tires and use Tie-downs and chain-binders. Lots of em. Tight. Haha
Also it's about 6 hrs each way.
Old 04-04-2016, 11:01 AM   #21
Bobbyz
Made the trip yet ?
