Old 10-13-2017, 03:31 PM   #976
55superbeetle
Yeah most likely mustang struts and a manual steering rack of some sort. I plan on keeping some resemblance of the factory front frame rails so it doesn't get called a racecar. Hoping to just tie in some good subframe connectors and a chromoly 8.50 cage. My biggest motivation on the mazda now is getting it done so I can start on my car.
Got the floor filled back in with room for the diff and driveshaft tunnel raised up, going to knock out the cage this weekend.
83 242, Turbo 6.0 LSX, E85, TH400, 8.8, 10.3@135
55superbeetle is offline   Reply With Quote
Old 10-13-2017, 03:38 PM   #977
SquareD
An Anomaly
SquareD's Avatar
Killer stuff.
Originally Posted by 55superbeetle View Post
6.0 with twin s366's. Reaaaaalllllly want to have AC in the car too, planning on rear mount radiator, but that could all be a pipe dream once I start mocking everything up. Probably going to move the firewall back some to make room. Lot's of dreaming that might not become reality.....but number one goal is to be able to drive it anywhere i want and run 8.50's, we'll see.....
Sheeeesh. Would you start it already.
1994 945ti | 15g @ 15psi, Turbosmart EBC, AEM Failsafe WB, 3"/2.5" exhaust, do88 intercooler, iPd cam, STS cam gear, Ostrich LH tune, sbabbs EZK chip, green giants, K&N, Yoshifab CCV/Can/Cap, iPd SS brake lines, TME, Eibach, BNE, Koni suspension, iPd sways, iPd panhard, TME upper/CT lower braces, forged BBS RG-Rs, Michelin Pilot SS, ecodes, V90 bits.
Old 10-26-2017, 12:07 AM   #978
55superbeetle
I bent up half of an 8.50 cage to tie the back of the car back together, tied in the 4 link mounts too. Went back and forth on doing the full cage but decided I can add it in the future if he decides too. Found a perfect 14 gallon steel tank to go back in the stock spot and stay under the floor, even get to plumb the stock filler neck back it for super street car status. Added a small sump for the 044's.
Old 11-11-2017, 10:29 PM   #979
WillettRun?
†John3:16
WillettRun?'s Avatar
thank you for sharing. inspiring as usual.
I still love Jesus and He still loves me.
MaxxECU Dealer/Tuner
WillettRun Automotive, LLC
WillettRun? is offline   Reply With Quote
Old 11-21-2017, 08:36 PM   #980
55superbeetle
Going back together for the last time I hope. My father in law who owns the car is pretty handy with a rattle can, turned out pretty decent. The cage was done with brush on hammer paint, probably wont use it again.
Old 11-21-2017, 09:33 PM   #981
soclosenotnear
Seconded.
check my feedback here
Old 11-27-2017, 02:25 PM   #982
55superbeetle
Originally Posted by soclosenotnear View Post
Seconded.
Thanks guys
Old 11-27-2017, 02:53 PM   #983
That looks awesome.
PS: I used the same paint you used on the cage for my wagon's roof rack
Old 11-27-2017, 04:04 PM   #984
55superbeetle
That looks awesome.
Thanks! I have seen the same paint used on other internet projects with better results, don't know if it was applied wrong or what. I should have done some test pieces first. It's not horrible but seems like it should have flowed better and been a little more uniform. At least its nice and hard and will keep it for rusting.
Old 11-28-2017, 10:15 AM   #985
boosted12a
weapon of mass detonation
boosted12a's Avatar
as much as i hate to see this done to a 1st gen RX-7, you did an awesome job. id like to see the final weight of the car.
91 940 SE, 119K, GOLD
03 540i M sport 6 gears of go! 200k, White
05 S80 2.5T, RED
09 XC70 3.2L, BLUE
10 335xi, (fun has a price), black
17 expedition El, (short bus), black
85 RX-7 GSL SE(efi'ed), BLACK
76 Suzuki RE5, BLACK
boosted12a is offline   Reply With Quote
Old 11-28-2017, 11:44 AM   #986
I think it's part of the "hammered" look. Looks like the intended finish to me anyway. Either way it's nice to use consumer-grade paint that takes minimal effort for fiddly, out of the way stuff like this!
Old 11-28-2017, 02:32 PM   #987
55superbeetle
Still needs the kirkey bolted in, driveshaft and fluids, not light but not a pig either.
Old 12-06-2017, 11:55 AM   #988
MikeJr.
Gloss Boss
MikeJr.'s Avatar
Where did you find the tank?
MikeJr. is offline   Reply With Quote
Old 12-07-2017, 03:11 AM   #989
55superbeetle
http://www.tanksinc.com/index.cfm/pa...cat/cat133.htm
Old 01-17-2018, 02:11 AM   #990
55superbeetle
Bunch more progress, and it's a runner now, hoping to take it out on it's first drive this weekend.
Old 12-07-2018, 02:35 AM   #991
55superbeetle
The rx7 has been daily driven almost all year, although he has pretty much parked it now that the weather has gotten ugly. Had to work out a few initial bugs but it has proven to be very reliable. I got a new job that is 5 minutes from my house so my family and free time has drastically improved. I've been helping a friend with a turbo 5.3 elcamino that has silly fast for such a simple combo and also building a 81 510 for a fun daily driver. At my new job we build mostly build hotrods and typical camaro/mustang/tri-five type stuff but we also have a full chassis shop that builds drag stuff. I have been learning a ton and hopefully next year will finally be time to build the 142.
Old 12-07-2018, 09:52 AM   #992
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
I'm very happy to see you back up and posting! Love the updates and was always impressed with the fab work.
You're swap was always a big drive for my build. Simple and to the point.
That RX7 is awesome.
Current setup - Aluminum L33/Summit Turbo Stage 2, Billet 80mm turbo, single Walbro 450 and Dual AEM 400's, Bosch 210's
3060lb no driver
3240lb with driver
Old 12-10-2020, 01:42 AM   #993
55superbeetle
Been a while since I've updated this thread. My Datsun got boring really quick with the sr20 so I cut it up and built a 6.0 cert chassis for it. I'm using a honda k24 with a powerglide this time. Plan on 2200 lbs and around 1k hp so hopefully it will be fast enough to justify the chassis.
Old 12-10-2020, 01:50 AM   #994
Old 12-10-2020, 01:22 PM   #995
NONHOG
equal opportunity car guy
NONHOG's Avatar
Keep the post coming!
Old 01-09-2021, 05:06 AM   #996
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
Holy **** lol. Just checked back in and was not disappointed lol
Old 01-16-2021, 02:33 AM   #997
55superbeetle
Datsun is almost a roller, just need to fininsh making the front lower control arms.
Here are some pics of customers stuff I have built at work too.
Old 01-16-2021, 11:38 PM   #998
Vol242vo
Keep it clean...
Vol242vo's Avatar
Good lord. Fab skills are strong with this one.
Derek
1 Owner - 85k mile 1980 242
-Project Thread-
Follow on IG: @vol242vo
Old 01-25-2021, 11:14 PM   #999
oldschoolvolvo
oldschoolvolvo's Avatar
Beautiful work. You have a gift sir.
-Mike
1998 V70 T5
1979 242 DL 16v
|Feedback|
Old 01-26-2021, 02:41 PM   #1000
BillyMaysHere
BillyMaysHere's Avatar
Wtf is going on with those valve cover vents coming into the cabin and tying into the tube/cage!?
I am actually the gentlest and kindest of souls, you know that...I wish peace and happiness to everybody
Was a sandals-and-socks elbow-patch-cardigan-wearing bearded college-professor 10mph-under-the-limit-in-the-fast-lane typical Volvo buyer from 1993 really caring about some sort of limited edition numbering?
BillyMaysHere is offline   Reply With Quote
