Don't mean to thread jack, but are they interchangable? Mean could I put the an '86 240 OD onto an '82 240? Both M46
reason I ask is because of the tailshaft flange sizes, the '82 small and the '86 wider.
OP you could have no overdrive operation for any of the perfectly good reasons that a Laycock overdrive doesn't work.
Start with..... Is it full of Clean ATF?
When you turn on the overdrive in fourth does it make the solenoid on the overdrive click?
More often then not the issue is electrical..... Be it in the wiring to the shifter, the relay in later cars, a fourth gear switch or crummy connections anywhere..... including the fusebox. Overdrive shares it's power in the fusebox with Rear Demist .....
So you've got a few things to check.
Mechanical? Didja replace the whole box? Did the Overdrive work in the previous car? If so what did you do to it that it is now Junk? Has to be your fault! You're the mechanic! Yer all like that!
Late M-46 with the P-Type overdrive uses a bigger mainshaft that won't break at the start line so those of us with that box will then break gears in the box when it makes traction!
With enough effort yes, you could put a P-Type in place of a J-Type overdrive but it is a lot of effort at putting a really ugly color of lipstick onto a dirty pig.
I suggest locating a complete M-46 with a P-Type that is in working order or repairing what you've got if you're not up for replacing the M-46 for a transmission that will take some abuse.
The bigger flange is for the driveshaft with three 'Large' U-Joints that don't have to be replaced every other year. If you've found one that is in good shape that is the right length for your car grab it and the flanges as fitting and put it in the car for a better driveshaft.
So in other words, I could just pull and swap the tailshaft flange and driveshaft instead? The two sizes of flange are interchangable?
I call shens on this thread.
