BDKR
Section 9
- Nov 16, 2003
- Horizons Cave
As some know from this thread, I stumbled onto an 850R while I was looking for something to replace the BMW with. And, in keeping with my pattern of naming cars after anime characters, this one is Batou from GITS SAC.
So far, the only pics I have are the two I put up on FB. Here is one.
The car is a missle and runs pretty damn good. Not as good as brand new I'm sure, but not at all bad either. Still strong as hell! There are some issues however and the paint is a big one. Don't know if you can see from the pic, but the clear coat on the top appears to be gone. Even stranger, it looks like it was deliberately removed. Why someone would want this I don't know.
Some more bad things? Hmmm....
Now the strangest thing so far is that the OBDII port is non-standard! Same physical design, different pinout! Thanx Volvo!
I have one of these...
It connects to the BMW and Fozzy just fine. I've used it to see and clear codes and via Torque I can get real time data and data logging to an Android device.
I want to use it this to monitor boost and get the gauges virtually right to a 7" device instead of installing more gauges.
So what do I want to do?
One of the earliest non-mechanical things that has to be done is the stereo. I take it that's a double din hole there?
- Vibrates or buzzes while at a light in gear (might be those poly mounts)
- Feels like the rotors have a glaze on them
- The exhaust drones around 2 to 2.5K
- The stereo sounds like there is a bit of static in it
- Did I mention the knackered paint
- One of the PO's painted the calipers and it doesn't really look that good
- Lookes like the wheels where painted since it seems to be chipping of in places.
- Dash cover (the bit across the top) looks like it's warped from sitting in the heat
- Some dash lights are out
- Starts kind of hard at times
- Lower it! I feel like I'm in a truck!
- Mo powah! I'll prolly go the IPD reflash route
- And fix the issues listed above
