Old 02-10-2016, 01:02 PM   #1
holdenjp
Default 1993 240 upgrades compared to previous years
Did the 93 240 have any optional parts that were made standard compared to previous years? I'm thinking things like sway bars, wheels, interior parts, heated mirrors, etc...?
Update: Sway bars weren't bigger. Car did have power heated mirrors and the cup holder armrest, but I think the armrest was probably an option not standard.
Didn't have time to check the rear diff. Hopefully I'll be able to check it next week.
1987 240 - Sold. Had it for 15 years. Car that turned me into a car guy.
1991 245 - Daily Driver, IPD Turbo cam advanced 2 deg, B230FT with 15G, TLAO Chips, MBC, AW71, Upper and Lower braces, IPD 25mm sways, Lowered on H&R springs and Bilstein HD's, Mille Miglia's 205/55/16
1986 Porsche 944 Turbo
Link to my feedback thread.
holdenjp is offline   Reply With Quote
Old 02-10-2016, 01:56 PM   #2
TempleUWS6
TempleUWS6's Avatar
R134 A/C and heated power mirrors is all I know of that were '93 only.
'90 245 340k mile DD
'79 242DL
'02 Trans Am WS6-Konis+Stranos, full exhaust, 353rwhp/373rwtq, Fikse FM5
'76 BMW R75/6
TempleUWS6 is offline   Reply With Quote
Old 02-10-2016, 02:10 PM   #3
JW240
All idiot, no savant
The driver side dash underside/knee panel is different in the last few years, not sure when it changed. Seems nicer than the sheet of felt that is used on earlier cars, although I have never seen one of those panels in person.
AFAIK 92-93 was the only year(s) with heated+power mirrors.
Speaker grills for 5.25" speakers. Dash without center speaker grille.
240 | 1991 | 345K Km | B230F+T | Cosworth T3 60/63 | M90 | TrueTrack (parked for a few months)
dd: 940 | 1992 | B230FB
Old 02-10-2016, 02:33 PM   #4
coalminer
That "Knee Bolster" as Volvo calls it is a added safety feature, and will help protect the drivers knees and lower legs in a head on collision. It's a good feature, and is very easy to remove and re-install if you need to get access under the dash.
coalminer is offline   Reply With Quote
Old 02-10-2016, 03:30 PM   #5
Jesse B
Fine Modern Gentleman
Jesse B's Avatar
(I think) rounded timing gears/belt and squirter blocks.
The automatics got a weird, generic-looking plastic shifter gate.
They dropped the matte black thing on the grills, door handles, and tailgate hinges.
'73 1800ES, now converted to m41!
'95 944
'95 945
'96 855T, Autumn Gold, now converted to m56!
'11 XC70, T6
Jesse B is offline   Reply With Quote
Old 02-10-2016, 05:42 PM   #6
vvpete
The most significant improvement for 93 only was the A/C evaporator/heater box, and condenser, much better. Also the 93 was the only year the rear diff came with the G80 locker differential, same as 940/960, but was an option. The knee bolster came in 91, my car has one. From 91-up front sway was 21 mm, and also heavier front springs 13.8mm wire, ABS.
vvpete is offline   Reply With Quote
Old 02-10-2016, 07:16 PM   #7
Wren
Porkchop Sandwiches
Wren's Avatar
'93's use the same evaporator as the '91 and '92 models. The rest of the system is different however. Not different in function, but different parts so that there isn't any interchangeability save for the compressor perhaps from a '93 and a '92 or '91.
I've never seen a 240 with a factory-installed G80. Not to say they weren't made of course, but they are extremely uncommon if they exist at all.
All of this is accurate except the '93's have matte door handles and tailgate hinges.
The most significant change IMHO is the change to R-134a for the a/c.
Wagons got tweeters in the rear doors.
I've read that power heated mirrors became standard. All of the 4 '93's that I own have them.
Old 02-10-2016, 07:53 PM   #8
iHateVolvoPeople
Did they actually come factory installed, or only as a dealer option? My 244 has a dealer installed 'locking differential' g80.
Feedback Thread
White liberals are the scum of the earth.
Old 02-10-2016, 08:34 PM   #9
Wren
Porkchop Sandwiches
Wren's Avatar
I've never seen a G80 that was factory or dealer installed. That's not to say that there weren't ones made it's just that I've never seen them.
Old 02-11-2016, 09:56 AM   #10
holdenjp
How would I know just by looking if it was a G80?
Old 02-11-2016, 01:09 PM   #11
Khrrck
Professional Amateur
Factory ones would be marked with the rear end info. I think it's a tag on the driver side (left) axle tube?
Dunno if dealer-installed would have any visible markings on the outside.
'87 240 budget wagon.
Old 02-11-2016, 02:05 PM   #12
iHateVolvoPeople
I don't think mine looked any different from the outside than my open diff car. The tag said 1041 instead of 1031 though I think. Both 3.31:1
Old 02-11-2016, 02:21 PM   #13
Hoggster
Hoggster's Avatar
The battery cables on '93s are different, I think they changed the positive and negative side to avoid shorts in a wreck.
Hoggster is offline   Reply With Quote
Old 02-11-2016, 05:57 PM   #14
iHateVolvoPeople
Yeah and they're stupid
Old 02-11-2016, 06:31 PM   #15
vvpete
I think they could be either dealer or factory. My 91 has a factory 1031 with a Dana 30, but only 93 is different. The whole rear axle and bearings are different also, same as a 940.
Old 02-11-2016, 08:20 PM   #16
iHateVolvoPeople
What axle do the 940s have? One of my 240s says 1030 (or 1031?) and the other says 1040 (or 1041?). What's the difference aside from the 1040/1 having the g80.
Old 02-12-2016, 01:36 AM   #17
122power
dude
122power's Avatar
under hood insulation as well. Some had fuses by the battery.
Classic editions had woodgrain trim, scorpious wheels 14"
Old 02-12-2016, 03:02 AM   #18
iHateVolvoPeople
I got scorpius wheels on a non classic 93 245.
Old 02-12-2016, 02:01 PM   #19
nel621
knee bolster started in 90 with airbag cars
Old 02-12-2016, 02:54 PM   #20
Dawson
Yes?
Dawson's Avatar
Not really an "upgrade" per say, but 99% of the '93s I've seen were LH 3.1.
Dawson is offline   Reply With Quote
Old 02-12-2016, 02:56 PM   #21
UhAudoe
Sittin' sideways
UhAudoe's Avatar
LH 3.1 drives so nice though.
Sometimes good enough is better.
Slow p.o.s. et13.51 @ 105mph - 13c, lh2.4
UhAudoe is offline   Reply With Quote
Old 02-12-2016, 04:02 PM   #22
Råda
Volvoretard/Partshoarder
Råda's Avatar
My 92 is switched compared to my 75, so I think it's before 93 they changed that
Jonas
Old 02-12-2016, 04:12 PM   #23
2manyturbos
No, more on the order of 95% of 1993 240s were/are LH 2.4. LH 3.1 was only used on the 5 speed manual 240, and even then, a small percentage of the manual cars were/are 3.1.
Old 02-12-2016, 04:33 PM   #24
tjanson
tjanson's Avatar
Most of them have a fuse block right at the positive terminal. I don't think it's a bad setup.
I can confirm that my '93 has Lh2.4 (originally an auto car), chrome grill surround, black power heated mirrors (silver car), R134a, the fancy battery cable, no center speaker hole, open diff with no drain plug in the cover, black hatch hinges, black door handles, dual squirt washer nozzles, round tooth t-belt & hood insulation. It has black beltline trim now but I can't remember if I did that or that was the way it came.
K-jet.org has a pretty good summary of the changes through the years, though it isn't 100% complete.
1993 245 DL; LH2.4, M47 - DD & Winter Beater
1978 242 GT - To Be Restored, someday
1993 245 DL - OEM+ Project
tjanson is offline   Reply With Quote
Old 02-12-2016, 04:44 PM   #25
2manyturbos
You probably switched the trim. I've had quite a few 1993 240s including Classic models and none of them came with all black belt line trim. Most, not all 1992 240s I have seen have had the black door handles, tail gate hinges and belt line trim.
