Old 02-12-2019, 05:18 PM   #1
Jesse B
Fine Modern Gentleman
Jesse B's Avatar
Default Rear washer check valve location
Does anyone know where the check valve for the rear washer is on a '95 945? And how do I access it? I've lifted up the floor panel on the driver's side, and I think I can see where the hose goes over the wheel well and then through a hole in the side panel of the trunk area. But wher's the check valve? Thanks!
Posted this in brickboard, but didn't get much of a response..
'73 1800ES, now converted to m41!
'95 944
'95 945
'96 855T, Autumn Gold, now converted to m56!
'11 XC70, T6
Jesse B is offline   Reply With Quote
Old 02-12-2019, 05:34 PM   #2
moustacio
On my 745 the check valve is accessed through the passenger side, rear light trim panel. I would think a 945 would be the same.
moustacio is offline   Reply With Quote
Old 02-12-2019, 05:55 PM   #3
Jesse B
Jesse B's Avatar
Is your reservoir and pump on the driver's or passenger's side? Mine is on the driver's side (non-turbo), so I would think they would've gone straight back with the hoses? Either way, I don't see one on either side.
Old 02-12-2019, 06:09 PM   #4
The Librarian
If this pic from the parts catalog is correct it's behind the right taillight.
Old 02-12-2019, 07:19 PM   #5
Fa182
Stage 1
Fa182's Avatar
That's about where it is on my Turbo 945. Replaced it a couple months ago, and it wasn't exactly behind the taillight, it was a bit more below, but I just had to follow the hose a little.
Old 02-12-2019, 08:24 PM   #6
Jesse B
Jesse B's Avatar
Thanks everyone! I'll have to go dig a little deeper.
Old 02-13-2019, 02:21 PM   #7
Jesse B
Jesse B's Avatar
For the record, it is in fact on the passenger side, behind the tail light on my 945. It's sorta glued to the metal with butyl rubber
