Old 06-01-2021, 12:53 PM   #51
amishmafia00
Has anyone else had issues with the Deeworks adapter not lining up correctly with an M46 bellhousing?
amishmafia00 is offline   Reply With Quote
Old 06-01-2021, 04:32 PM   #52
thessejway
¯\_( ͡❛ ͜ʖ ͡❛)_/¯
thessejway's Avatar
I just used it and had no issue at all.
Is it possible you got the wrong adaptor or Bellhousing? Here are some images of mine if you want reference
____________________________________________
1993 945t Build Thread
Old 06-02-2021, 10:30 AM   #53
amishmafia00
Is than an M46 also? do you know what your casting number is?
I don't see any similar adapters on the site. My bellhousing has a sticker on it that says
M46 NR 1208230
Fabr NR 113?28 (can't definitively read the ? digit)
Casting number is 1023531
Old 06-02-2021, 10:52 AM   #54
thessejway
¯\_( ͡❛ ͜ʖ ͡❛)_/¯
thessejway's Avatar
Yeah it's an m46 bellhousing
Unfortunately I don't have access to check the casting number at the moment, nor have I been able to find images of it. But here are some images of the m46 trans it came off of if that is any help.
Old 06-02-2021, 11:19 AM   #55
amishmafia00
Default Pictures
I just noticed that I can turn the bellhousing on the adapter to a point where the holes are all off by the same amount in the same direction. Like the zero point was off for that operation. I was trying to post pictures but not having much luck
Old 06-02-2021, 11:42 AM   #56
thessejway
¯\_( ͡❛ ͜ʖ ͡❛)_/¯
thessejway's Avatar
Hard to tell, but comparing your images to mine, looks like you might have a slightly different bellhousing, possibly an m47? But I really don't know
Old 06-02-2021, 11:49 AM   #57
amishmafia00
those pictures were before I realized they were all off the same amount. In that position I am able to put one bolt in. The sticker says M46, Even if it were an M47 it's supposed to work. I contacted Deeworks.
Old 06-02-2021, 11:49 AM   #58
thessejway
¯\_( ͡❛ ͜ʖ ͡❛)_/¯
thessejway's Avatar
Very possible.
I think Deeworks Cuts the center hole to order based on the type of cd trans you have
