Old 05-24-2021, 05:40 PM   #1
jtbechtold
Default Pinout for DSM CAS with MaxxEcu
Well I have come here after not finding a direct answer for my issue. I am installing a Maxx ecu on a b21ft.
The question is. What is the pinout on the DSM cas?
i have four wires white,black,yellow, and red. If someone has experience with the Maxx ecu that would be fantastic but really i just need to know what those wires do and not what i need to hook them up to.
Most of the info i find is all Megasquirt related and while it is helpful is also complicated things for me. looking through pages of DSM cas info that is all talk about Megasquirt.
Thanks in advance and thanks for this forum,
The other Jesse in Tucson
jtbechtold is offline   Reply With Quote
Old 05-25-2021, 08:06 PM   #2
See: http://forums.turbobricks.com/showpo...&postcount=208
Old 05-27-2021, 08:34 PM   #3
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
whether it's for megasquirt or something else shouldn't matter from a basic function standpoint.. the power in, ground, and two signal outs don't change based on what they're connected to. the big question with the maxxecu is whether or not it's got internal pull-ups on the cam and crank inputs, or if you have to do that externally.
Megasquirt Tuning!
Old 05-28-2021, 12:31 PM   #4
jtbechtold
Thanks, I had not seen that the thread, but that is exactly what I needed. Car is running.
Old 05-30-2021, 12:27 PM   #5
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
all maxxecu units have internal pullups for every input, cam/crank, digital/VR (software selectable) , except for Analog currently. most units have 2 dedicated spare thermistor channels and 8 spare 0-5v AIN channels. pro unit has 30 spare analog inputs
Old 05-31-2021, 09:59 AM   #6
linuxman51
linuxman51's Avatar
I need to get ahold of one those to play with. have they gotten the 6 and 8 speed stuff working yet for gm transmissions?
Old 05-31-2021, 10:42 AM   #7
Also the BMW N/S55 7-speeds?
Old 06-05-2021, 12:37 AM   #8
DNAsEqUeNcE
†John3:16
Are you referring to the CANBUS/TCM based stuff? no, and i don't see that being very high on the to-do list.
you know who to call to get one.
Old 06-05-2021, 12:39 AM   #9
DNAsEqUeNcE
†John3:16
S55 DCT (M4, F80, ect) is on the way. that will be canbus controlled, and you do not have to have a GWS shifter from the car to make it work. you may use a keypad, your own switches, or an CAN switchboard with your own buttons, ect. The GWS from that car can be used if desired, or the DCT Shifter, ect.
