Old 06-05-2021, 10:59 AM   #151
hk 40
Banned
Im modding the two I have this way and adding digital pots so I can store settings and return at any time. I would like to add visual display of the knock and boost rise rate.
Regards
Hubert
hk 40 is offline   Reply With Quote
Old 06-11-2021, 05:16 AM   #152
hk 40
Banned
The pots I chose for the project Xicor X9102 (1kohm dpot) and a X9503 (50kohm dpot).
Regards
Hubert
Old 06-11-2021, 05:51 AM   #153
hk 40
Banned
The application
A test circuit to run with the debug terminal.
Regards,
Hubert
Old 06-11-2021, 12:46 PM   #154
hk 40
Banned
BOM
Qty.
1 Xicor X9C102 1000 ohm digital pot
2 Xicor X9C503 50 kohm digital pot
1 39k ohm 1/4 watt resistors.
1 Jumper wire
You can also get a knock sensor with shielded wire already attached.
Regards
Hubert
Old 06-15-2021, 08:09 AM   #155
hk 40
Banned
The 1000 ohm digital pots for each unit have arrived first. I can set a test circuit with code now.
Regards
Hubert
