Old 05-27-2011, 10:52 PM   #1
Magnum TE
Broke another B230F+T
Magnum TE's Avatar
Default identify cam : JFKA stamp
I thought I was running an ipd turbo cam...
I pulled it today and it's stamped JFKA and has a green band between cyl #1 intake and exhaust lobes.
is this really a K/A grind?!
Goldie Bricks - '92 940T : B230F+T MSnS-e...
The Black - '98 318i : stock drive-train DD
I have some cool stuff done to my cars
The Gold Car: Owner since 2001
B230F+T MS1nS-E / Ford T5, 1pc DL
ebay FMIC / Mechman Alternator
T3 60/.63 ATP WG / 98#/hr injectors
Full 3" Turbo to tail / IPD TP Cam
IPD bars / Coilovers
Koni Dampners / Lower Chassis brace
NIW-T3 camber plates / Full poly front end
Full Kaplhenke Rear end
-Torque rods -PH Bar -Subframe
Daily Parker
Magnum TE is offline   Reply With Quote
Old 05-28-2011, 01:14 AM   #2
Magnum TE
Magnum TE's Avatar
intake and exhaust lobes are ~47.3 high. I don't have any way of measuring the lift untill I reinstall it... if I'm going to reinstall it.
derp
lift 11.65mm
Old 05-28-2011, 02:30 AM   #3
Morten VJ
max.Lift = lobe height - basecircle - valve clearence.
Morten VJ is offline   Reply With Quote
Old 05-28-2011, 04:13 AM   #4
Magnum TE
Magnum TE's Avatar
11.65 lift on both intake and exhaust is what I crudely measured, I guess it could be an ipd turbo cam
checking that
http://www.turbobricks.com/resources...ontent=camspec
IPD Turbo cam 11.95
Old 06-12-2011, 07:59 PM   #5
klr142
Turbo, what?
klr142's Avatar
It's out of the car? What does it say on the back of the cam?
Old 06-12-2011, 08:43 PM   #6
Magnum TE
Magnum TE's Avatar
the only marking it has on it is on the outer circumference of the tail of the cam. There's no stamp like one would find T or M etc. The JFKA isn't impact stamped like with a hammer and set, it's like dot-matrix printed into the metal, it doesn't look hand written it looks machined.
Kinda strange, I put it back in the car for now it's limping along on one mismatch valve spring and retainer. I'm driving the gray car until I figure out what's to become of the gold one.
It's supposed to be an older batch of ipd cams like pre '03? I don't even know how long the thing's been in the car. I guess I could send a PM to Cameron and see if he knows anything about it.
I'll get some pics of it when I pull it to replaced the valve spring and retainer. I may just drop it in the gray car since I've been driving that.
Old 06-13-2011, 12:40 AM   #7
gsellstr
gsellstr's Avatar
The IPD turbo cam's I've run were either a VX which was marked with an engraver, a first-gen IPD which was the same, marked PH1, and a later IPD cam with the dot-matrix style stamping around the circumference of the tail of the cam, instead of on the end. That engraving was HG20 or something like that.
Maybe the cam is Just For Kicking Ass?
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 06-13-2011, 01:06 AM   #8
Magnum TE
Magnum TE's Avatar
It's a good dam cam it pulls like hell from 3k till 7k, I just was surprised that it didn't say PH1 on it when I pulled it.
Old 06-03-2021, 09:42 AM   #9
Eakin
Eakin's Avatar
Reviving this thread because I just found the same cam in a used head that I bought recently.
The seller wasn't sure of the origin, but knew that is was aftermarket and assumed IPD.
I measured the lift and got somewhere between 11.5-11.6mm on both intake and exhaust.
Sent photos and those measurements to IPD to see what they though. Their response was that it wasn't one of theirs and that they weren't sure where it was from. They agreed that it didn't seem to match any of the stock grinds, but couldn't help much beyond that.
Any chance someone has sorted out the origin of these cams sometime over the last 10 years?
84 242T - summer
93 944T - daily
87 764T - rally
Eakin is offline   Reply With Quote
Old 06-03-2021, 09:46 AM   #10
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
hm. wonder if that's the same head that randy p. runs in his 740. lemme ping sam...
Megasquirt Tuning!
