Old 05-29-2021, 08:29 PM   #1
Zev Fisher
Default Can anyone ID this bumper?
Hi All,
I have a 1975 245DL and want to swap out the huge factory bumpers for something more low profile. Does anyone know what other year bumpers are compatible with a 1975 and also what bumper is on the 245 linked below?
http://3.bp.blogspot.com/_WSAzGCO4NT...2Bsky(web).jpg
Thanks!
Zev Fisher is offline   Reply With Quote
Old 05-29-2021, 08:55 PM   #2
PCH
The one on the pic is 145.
You can fit later style 240 bumpers on a '75.
Old 05-29-2021, 09:47 PM   #3
But the bumper filler trim looks a little off because it's shorter on the returns.
Old 05-29-2021, 10:47 PM   #4
lookforjoe
Making Volvo Parts Fit
lookforjoe's Avatar
Oof. Better off spending your dollars on a later drivetrain swap. Relying on the B20 in a 75 MY sucks - or did you already take care of that aspect?
Old 05-29-2021, 10:50 PM   #5
Zev Fisher
Thank you!!! So are the 145 bumpers a direct or similar fit on the 240 if I make custom brackets?
On the later 240 bumpers if I went that route would using the later bumper filler trim (the 3 piece with the chrome) as opposed to the earlier all rubber single piece work to fill that gap on the return?
Old 05-29-2021, 10:54 PM   #6
Zev Fisher
I was actually going to LS it, but upon further digging realized it has a 1993 B230 marine block with an 86mm stroke and forged crank so I’m working with Josh @ Yoshifab on a forged bottom end turbo motor and his CD009 swap. Does that qualify as a later drivetrain? ;)
Old 05-29-2021, 11:04 PM   #7
No the 140 front bumper is a different shape to follow the 140 front valance.
Also they aren't nearly as wide [tall] so they will probably be in conflict with the 240 shock / strut style mounts.
Maybe if you can drill a bunch of holes in the exact right places without a pattern or anything to go by.
Not to mention the anchors are ~ $3 each, and used ones don't hold the trim securely.
Honestly I'd just take the slight mismatch and go / live with it.
Old 05-29-2021, 11:11 PM   #8
Pro-tip:
The 83-85 'Toy' bumpers are the lightest, but you'll also need the corresponding mounting struts.
Old 05-30-2021, 09:13 AM   #9
Zev Fisher
Honestly I'd just take the slight mismatch and go / live with it.[/QUOTE]
Just so I understand correctly, you mean I should use the 83-85 bumper & struts but run the earlier 75 full rubber wraparound filler trim and just live with that mismatch correct?
Old 05-30-2021, 10:54 AM   #10
PCH
This is what late bumper looks like on a '76 with the original body/bumper seal still on: Scroll down to the middle of the page to the Berkshire Green Wagon https://www.240turbo.com/volvo240.html
The fenders are from something like '83- that's why there are no trim holes around the corner lights. But the holes for the bumper trim lined up with the early rubber seal.
Old 05-30-2021, 11:50 AM   #11
Zev Fisher
Awesome, thanks so much y’all. Looks like I’m going shopping for 83 to 85 bumpers ;)
Old 05-30-2021, 04:37 PM   #12
Default Anways
Hell of a lot easier to find than good 140 bumpers.
