Old 06-02-2021, 05:51 PM   #1
90volvo
Default who making over 400hp and can drive extended miles.
Out of curiousity, who is making over 400hp that can drive their car for 8 hours in comfort. When I mean comfort, Ac in 100degree weather, power steering, nice stereo, good strong trans, no worries about over heating or popping the hood every 100 miles to check fluids. If you feel like your car can do this, I would like to know your setup. Thanks
B230ft rebuilt -MS-Turbo-E85
1985 240 Work in progress.
Old 06-02-2021, 06:10 PM   #2
JohnMc
JohnMc's Avatar
Ineligible due to lack of A/C. But it's a turbo LS with a 6 speed manual.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 06-02-2021, 06:24 PM   #3
volvohyes
I'm curious about this too, anyone with a redblock?
Seller Feedback
volvohyes is offline   Reply With Quote
Old 06-02-2021, 07:02 PM   #4
RvolvoR
Not mine specifically, but when I worked at RSI I took their white wagon and drove it from Portland to Sacramento/Davis/SF with no issues all the way there and back, AC blowing cold the whole time in Sac valley heat. The car made 390whp on 91 pump and 525whp turned up on E85 (with maxed out ID1000 injectors) iirc. All that with an 8v.
My old 75 which made 350whp on an 8v made many trips from Sacramento to Portland and back with no issues, but that is discounted because that was me in my early/mid 20s when I hated myself and though AC was for weaklings. The car did it with little issue and got 27mpg going 75-80mph on the freeway on pump. On e85 it'd do 23-24mpg highway.
Old 06-03-2021, 03:36 PM   #5
90volvo
Man I thought we would have more than just a couple?
Old 06-03-2021, 05:56 PM   #6
Bloody244
well i dont know how much my car makes but i guess probably 300hp and thats on a skinny rod i would turn up the boost but after 17 psi it just stutters and knocks like hell
1987 244 B230f+t @17psi 19t V16t cam Lite Ported 531 Head Stock Skinny rod Block Do88 intercooler Stock AW71
Instagram @Blue__244
Praying for a window free block
Bloody244 is offline   Reply With Quote
Old 06-03-2021, 06:34 PM   #7
RvolvoR
your car doesn't make 300hp with a 19t at 17 psi
Old 06-03-2021, 07:52 PM   #8
Hank Scorpio
Chubfest 2009 Survivor
Hank Scorpio's Avatar
my t5r did 400bhp+ and was reliable. I moved out of state and had no garage for quite a while it and then drove back home again (sac->seattle->sac).
Old 06-04-2021, 12:29 AM   #9
90volvo
Im not a big 850 fan but man you did an excellent job on your build. Id swap my 90 240 straight across.
Old 06-04-2021, 08:26 AM   #10
JohnMc
JohnMc's Avatar
I've been pondering a way to fit an compressor in my car. It would have been easier with an LSA supercharger sitting in the valley instead of a turbo and crossover piping hanging around the front of the engine where a compressor would normally go.
Maybe a super-duper alternator and an electric compressor.
Old 06-04-2021, 08:50 AM   #11
Marvelous3
Who engineered this?
Marvelous3's Avatar
Red wagon doesn’t have ac - it could just $$$ - but I drove it all over the place.
I mean, if you’re driving it on the highway that’s probably the least stressful way to drive. Steady state with lots of air flow and low amounts of rapid acceleration. Any property functioning car should be able to handle that. If not, a stage 0 is in order. 100hp or 1000hp.
Old 06-04-2021, 09:25 AM   #12
Ju1cE
Ju1cE's Avatar
Just yesterday I was thinking about driving my 262c to a family reunion that will be at least an 8 hour drive...but at only 300hp currently and no A/C I don't think I fit the bill either. But I am also still very conservative on boost at the moment and have plenty of injector headroom, I think the smart order will be to replace the transmission before I crank up the boost just so that M90 can be removed still in one piece...the CD009 that I plan to put in will take any abuse I'm willing to throw at.
Agree with Marvelous3 that highway cruising is the easy part, having AC in a performance car is likely the bigger hurdle in and of it self.
82 244DL+T - 182k +T, TME springs, full poly, full ipd suspension
84 242GLT - 290k Going back to stock? Maybe for sale soon??
89 285T V8BRICK's Wag 302 Turbo, T5 trans, Freshly re-wired MicroSquirt, was still working through issues....then burnt to the ground
The Betrone (not done, but on the road) Captain Bondo's Engine, 8.8, etc.
65 122S- In loving Memory of Dad. 12-3-10 Died in an accident while driving a 244, there are no such thing as a grandpa car guarantee
Ju1cE is offline   Reply With Quote
Old 06-04-2021, 11:40 AM   #13
90volvo
Mine is lacking the AC as well. With the header and turbo there is no room for the accumalator. So, I will go with the drier setup. I have my AC compressor mounted but I hate putting a condenser in front of the intercooler.
Old 06-04-2021, 02:57 PM   #14
hikerguy
hikerguy's Avatar
Yeah... Not many.
180hp still cruises down the highway fast enough for jail time, with the AC on and 20mpg.
+1 million miles of white block sitting in the drive way
hikerguy is offline   Reply With Quote
Old 06-04-2021, 06:06 PM   #15
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
I don't drive anywhere. I'd like the blue car and the black wagon and the v8 car to do those things (the v8 car is set up for it, but the damn a/c keeps leaking down somewhere), but I haven't had the time to set aside to make it happen.
Megasquirt Tuning!
Old 06-04-2021, 09:56 PM   #16
Jussi Alanko
Look at youtube bamses turbo underpants, it have over 600hp or something like that and they drive car from finland to sweden, something about 1000miles as a whole.
Jussi Alanko is offline   Reply With Quote
Old 06-05-2021, 05:29 AM   #17
283SD
My 78 V8 wagon was an A/C delete car. At one point I gathered all the parts to make it have A/C. But it would add a lot of stuff to the engine bay[GM compressor that a 262C used,brackets from a late60's Corvette etc]. 33years later and 300K miles later I still love to drive it w/o AC.
Old 06-06-2021, 11:09 AM   #18
JohnLane
I drove the rally car all over the Pacific North West. No A/C because rallycar. Controlled ride that was not abusive. Had a lot of fun with it. Jerico dogbox took all the power. Just not for big power in reverse.
