mikep
Vintage Ride
- May 24, 2003
- 38? 27' N 75? 29' W
If I remember correctly, the vx is a V cam with its nuts cut off on the exhaust side. Since the exhaust ports and shrouding are so bad on the 8 valve Volvos, you would want, if anything, MORE lift and definitely more duration to get more air past that horrifying short turn radius.
A quick read on split-pattern cams:
https://www.onallcylinders.com/2014/03/10/monday-mailbag-single-pattern-vs-dual-pattern-cams/
