Go Back   Turbobricks Forums > General > article composition > the vault
Old 04-01-2013, 09:51 PM   #576
r0k0
r0k0's Avatar
k well fans works great, turns on and then off when coolant is cold enough... BUT as soon i turn off the key, fans goes back on... WTF is wrong...
this is the 3rd relay i've went threw in 2 weeks to try and fix this damn problem
1994 854 2.4 5 Speed - Crashed in 06
1990 744Ti - Sold to Nephew
1993 245 - SOLD
1991 744Ti - Project - 16T@15PSI, Brown Tops, Side Exhaust, Intake
1993 244 M47 - SOLD
1996 854 2.4 Auto - SOLD
1987 744Ti - SOLD
r0k0 is offline   Reply With Quote
Old 04-03-2013, 06:12 PM   #577
klr142
Turbo, what?
klr142's Avatar
AS SOON AS you turn the key, or a little while after? It's normal for the fan to run after the car is shut off in some circumstances, but it should not run for more than 1-5 minutes, MAX. Does it keep running indefinitely?
Old 04-03-2013, 06:40 PM   #578
PDX240
Back from the DEAD
PDX240's Avatar
Yep, mine runs for about 30 seconds after shutdown when it's real warm.
You could try a slightly lower t-stat or slightly higher temp fan sensor if it runs for too many minutes after shutdown, i would think.
My Blue 1986 245DL
Pdx240 feedback http://forums.turbobricks.com/showth...ghlight=Pdx240
PDX240 is offline   Reply With Quote
Old 04-03-2013, 06:43 PM   #579
doucheNozzle
doucheNozzle's Avatar
Already asked. Can't seem to get him to answer properly. That's fine. His money.
'93 944 T - #TrophyVo
'00 XC70 SE - Slow
'11 XC90 V8 - Torque Monster
Old 04-03-2013, 07:52 PM   #580
r0k0
r0k0's Avatar
Fan will not turn off at all, even when cold its turns on right away after key is off
Ive tested up to 20min without shut off
Old 04-03-2013, 08:06 PM   #581
doucheNozzle
K time to start tracing wires. Where is your trigger coming from?
Old 04-03-2013, 08:44 PM   #582
r0k0
r0k0's Avatar
Coolant temp in rad, all wires are place identical to page 16 of this thread
Old 04-03-2013, 09:01 PM   #583
doucheNozzle
As in the switch on the radiator or a probe?
Old 04-03-2013, 09:57 PM   #584
r0k0
r0k0's Avatar
The coolant temperature sensor on the top passenger side, the only sensor thats on the rad, the same one shown on the picture on page 16
Old 05-24-2013, 01:15 AM   #585
ZoomSpeed
ZoomSpeed's Avatar
ok, so I did this conversion with a relay from a 99ish S60, a coolant temp sensor from a 92ish 740, and an electric fan from a 94? buick century, hooked it up as per what I found in the thread. I do have some electrical knowledge, but the hardest part of this was mounting the fan.
I used the high speed setting on the relay to go to a manual switch for diagnostic purposes or something, works great.
The fan rarely comes on, only when sitting in traffic for a while. Even at 30km/h it doesn't go on.
I swear the car has more power too, it seems to rev faster, and overall feels more energetic.
1989 Volvo 240 Wagon - +T, Cut iPd springs, Koni shocks, front dual sway bars, Short shifter, Truetrac. - The Autocross Champ and Winter Drift Machine
1989 Saab 900 Turbo - Aero wheels, Modded APC - The Summer Highway Blaster
My 240 Build Thread
ZoomSpeed is offline   Reply With Quote
Old 05-26-2013, 03:25 AM   #586
122power
dude
122power's Avatar
Does anyone have the part numbers for the temp ranges on the sensors, stock volvo ones anyway. The push in style.
Old 06-02-2013, 12:04 PM   #587
r0k0
r0k0's Avatar
So i did more testing before i remove the efan and install a aisin tropical clutch fan
Replaced the fan switch in the rad for a newer one, doesnt seem to trigger still but my relay works since when i tested them i kept putting them on 12v and wouldn't trigger since it needs grounding instead haha
But according to the picture for low speed is plugged on the blue/black wire from the fan switch, but read it needs to be on the ground from the fan switch
As soon i put it on the ground it turns on right away and doesnt turn off and once plugged on the fan switch doesnt turn on even hot
Old 06-02-2013, 12:35 PM   #588
doucheNozzle
Make your own thread.
Old 06-02-2013, 01:36 PM   #589
r0k0
r0k0's Avatar
This is a efan thread
Old 06-03-2013, 10:08 AM   #590
doucheNozzle
This is an efan thread
Yes. However, it's not troubleshoot the idiot's issues when he won't listen to anything we have to say or WON'T GOT BUY A DAMN MULTIMETER.
So again, make your own troubleshooting thread.
Old 06-03-2013, 07:49 PM   #591
volvo740b234/531
volvo740b234/531's Avatar
Well all I did was spend 70$ for an electric v6spec and wired it in place of the stock auxillary cooling fan removed my ac system my powersteering. And stock airplane prop used one kevlar belt for w.p alt.cs and haven't overheated since even in 80 degree ruch hour traffic
1989 740 gle:
Roller/ project
2008 dodge nitro r/t:
Daily
1976 wheelhouse c-101:
Predator 412+t project/build
volvo740b234/531 is offline   Reply With Quote
Old 06-03-2013, 07:57 PM   #592
volvo740b234/531
Even works as switched 2 speed and alternates at 185-197 temps with a little watter wetter just for added help
Old 06-04-2013, 07:35 AM   #593
jmphillips
I have some thoughts about fan conversions...years ago before I heard of turbobricks I installed a Flex A Lite 2800 cfm fan from Jeg's, intended for 5.0 Mustangs, thinking that it would have more than enough umph. This was probably around 1996 or so...forget the brand of fan controller but it can handle at least 15 amps (I think), have a sensor in the radiator fins, and also a wire tapped into the a/c wire that runs to the low pressure switch on the receiver/drier. So fan comes on with a/c, also comes on with engine temp and has adjustable setting. Still works after all this time. It seems that my a/c has never been quite as strong and more likely to detonate under high boost on hot days - also temp creeps up on hot days at fast highway speeds, but not seriously. This is already an 18 amp fan. Actually considering switching back to a good (new) clutch and fan plus shroud. The (at least the factory intercooled 84.5 and 85) had an alternator downsized from 70 amps to 55, though I have the 70. Someone else mentioned the pusher fan in front of everything- according to the Volvo FSM's, this doesn't come on with the a/c- it's more of an emergency fan, and doesn't come on until the temp is approaching the red. I forget the temperature. Anyone know of testing done showing how much hp an engine (or even better, the 240 fan) driven fan can use? I have to wonder if it isn't that much...18 amp fan even if 100% efficient is 216 watts...sorry if this is off topic- not sure if whether to do the conversion belongs in a thread about how to do the conversion
jmphillips is offline   Reply With Quote
Old 06-04-2013, 07:49 AM   #594
r0k0
r0k0's Avatar
I went back to aisin tropical clutch fan 75$ at fcp euro
Old 06-10-2013, 03:16 AM   #595
Ansel+
ABG
Ansel+'s Avatar
Just installed mine.
960 fan with 2 speed relay. Wired the high speed to a switch and the low to the Saab T with a 87/92 sender in the lower radiator hose. Works great.
Ansel+ is offline   Reply With Quote
Old 06-11-2013, 12:03 AM   #596
Hathos+
I own 3 cars now
Hathos+'s Avatar
Similar setup to onsel's, but reversed. Hooked up low speed to switch, and high to a temp sender in the radiator. Fan blows strong, and even stronger when left to the "emergency" ovar-heat mode. So far, it's lightyears ahead of the old fan in comparison.
Hathos+ is offline   Reply With Quote
Old 06-11-2013, 02:48 AM   #597
740spinouts
740spinouts's Avatar
so i have 2 12' fans from amazon. they are 12v 80w fans would one be enough? they both don't really fit over the radiator.
740spinouts is offline   Reply With Quote
Old 06-11-2013, 10:29 AM   #598
doucheNozzle
Considering that they are 12 feet, I wouldn't think that they fit.
They're 80w? That's 7amp. That's nothing. Factory is 30 I believe.
Old 06-12-2013, 12:09 PM   #599
klr142
Turbo, what?
klr142's Avatar
I'm worried that the fan won't kick on early enough in your setup with the 92/87C switch in the lower radiator hose. Especially in a high ambient temp day with a turbo car running anywhere near detonation threshold. I will likely do something similar but see how that switch in the upper hose works(because I think that's the only easily available switch for the Saab T, not because I want it!).
On my blue car, I run an 82/77C sender in the radiator and with the 87C thermostat in the engine. With that setup, I can't complain AT ALL. My temperature gauge barely goes up before the fan kicks on and it keeps things nice and consistent. That car is so close to the detonation threshold that it does detonate, which is part of the reason for why I'm not driving it regularly. When the temperature goes up, it makes a noticeable difference. I wouldn't even be able to drive the car if it got any hotter and the temps weren't as controlled.
A stock b21/b230 won't care nearly as much, but if you start pushing the envelope, you will want to better control your temps!
Old 06-12-2013, 05:02 PM   #600
Ansel+
ABG
Ansel+'s Avatar
I had that thought too, and I am going to track down a different sender, it kicks in slightly above the halfway mark on the gauge. I might just swap the low speed to the switch.
http://www.busdepot.com/82395948182
this is the right one yes?
