Old 09-14-2022, 11:23 PM   #1
QisofrKuin
Default Hmmm...what is all this? And general work advice.
I finally have a concrete driveway so I can properly jack up my car and, oh boy!, a world of drivetrain problems were just ripe for the discovery. I'm replacing my rear trans seal, speedo o-ring, differential pinion seal, and the central driveshaft carrier support at the moment. I also noticed all this wetness above what I think are the brake lines. I'm not sure what would be causing this exactly so thought I should ask.
Also, I assume I might as well take out the driveshaft to make all these jobs easier since they all need to be done, so I wanted to know if there is anything else I ought to do while I'm down there. Thanks!
QisofrKuin is offline   Reply With Quote
Old 09-15-2022, 07:40 AM   #2
c1800
What is this? Looks like a broken line.
File Type: jpeg 3D404868-8770-45B1-9EE6-9E48105629EC.jpeg (68.5 KB, 63 views)
Old 09-15-2022, 08:43 AM   #3
OVERDRIVE
OVERDRIVE's Avatar
It should be easy to distinguish what fluid that mess is right there. If you had a break fluid leak you'd know really fast. If you're doing the rear seal on an automatic it's most likely from a worn bushing, a new seal will most likely not fix the leak if the bushing is already worn.
1990 244 DL AW70 189 Polar White -hers
1991 M5 668 Schwartz II over black nappa. -his
OVERDRIVE is offline   Reply With Quote
Old 09-15-2022, 12:31 PM   #4
shoestring
shoestring's Avatar
Is it your fuel return line?
Old 09-15-2022, 12:57 PM   #5
QisofrKuin
It doesn't seem to have an odor which makes me think its not fuel. I've never had any problems with the breaks. I guess I'll just have to trace these out a little more carefully. Luckily I'm doing the seal on an m46 so hopefully it takes care of the leak at the trans.
