Old 09-10-2022, 12:29 PM   #1
Murploid1
Murploid1's Avatar
Default Strut advice
Hello,
Looking for some advice regarding front struts on a 1982 volvo 244.
Front driver side strut is making a clunking sound - no idea when they were last refreshed, likely requires doing.
I pulled off the plastic caps and the rubbers look ok. However the nut on the drivers side is not tight - passenger side is fine and doesn't clunk.
I tried to tighten that nut but it will not, just spins around. There is little resistance.
What am I overlooking here? Do i need to jack the wheel up before attempting to tighten or something?
Murploid1 is offline   Reply With Quote
Old 09-10-2022, 12:38 PM   #2
Radtap
Radtap's Avatar
You need a special socket for tightening struts, it’s a large socket to grab the big nut and then another tool fits in the center to grab the strut itself, hold the center one with an open wrench and grab the other socket with another wrench and twist
Feedback
Radtap is offline   Reply With Quote
Old 09-10-2022, 01:11 PM   #3
Murploid1
Murploid1's Avatar
Any tool recommendations or links? Also, clarification of the size?
Old 09-10-2022, 01:19 PM   #4
Murploid1
Murploid1's Avatar
Looks like I can use a go through socket set...
Old 09-10-2022, 01:43 PM   #5
The Librarian
The tool needed to hold the strut varies with manufacturer. Stock struts have a double D shaped shaft and the nuts are 24mm.
http://hiperformanceautoservice.com/...tNutTools1.jpg
Old 09-10-2022, 01:52 PM   #6
Murploid1
Murploid1's Avatar
Thanks. Apparently the tool is identical to Lisle "Universal Strut Nut Remover 63400" - which I have managed to order...
Old 09-10-2022, 04:43 PM   #7
Old and boxy but good.
The other tool you will need is a deep offset box wrench to fit on the nut and turn it.
Old 09-10-2022, 06:39 PM   #8
Radtap
Radtap's Avatar
I think I got a generic set from an auto parts store and has worked with a few different brands, not perfect but works
Old 09-10-2022, 11:51 PM   #9
James M
Bored member
James M's Avatar
Like it or not spamming the trigger a dozen times for a few seconds will have the issue solved. Only reason I've even gotten out an air impact in years
Old 09-11-2022, 01:02 AM   #10
Murploid1
Murploid1's Avatar
I thought about the air impact wrench but I would like more control and there is the potential to create a larger problem.
Regarding the deep offset box wrench, not sure I need that in addition to what I purchased? Using that tool may work with vice grips or channel lock pliers..
Old 09-11-2022, 12:18 PM   #11
On a spinning strut shaft. I cover my slip joint pliers jaws with tape and hold the shaft by lifting up the dust boot and reaching through the spring. A vice grip works well, too. Then I use the impact gun to spin it loose easily. Of course only get it loose then put the spring compressor on there before completely removing the nut. We don't want to hurt yourself or anyone helping.
That works great for removal. For installation I use the Volvo tool.
Old 09-11-2022, 01:00 PM   #12
The Librarian
Spinning the shaft with an impact gun can unscrew the working piston inside the strut.
Originally Posted by Bilstein
Removing and installing shock absorbers/suspension parts with an impact driver (also pliers on the piston rod/shock absorber tube) can damage the shock absorbers and create noise later on. There is also a risk of the screw fitting of the working piston on the piston rod coming loose. On gas-pressure shock absorbers, the piston rod could then be ejected from the shock absorber (caution: hazard!). The use of pliers also damages the finely machined surface – average surface roughness (Rz) = 0,2 µm.
Old 09-11-2022, 09:49 PM   #13
RickATL
RickATL's Avatar
Default not identical
I went through so much trying to deal with this the past few years I thought I'd chime in here. I bought so many different "universal" tools and none including the lisle worked. I bought the Volvo special tools in the end, I must say that it was the best money I ever spent. I have several 240's so it made the investment worth it, but man oh man, I am so glad to have the special tools. If you can work out a loaner or something it is really worth it.
Feedback thread: https://forums.turbobricks.com/showthread.php?t=353892
91 245 re-christened “The Mistress” 012021
93 244 "Lars"
92 245 "Astrid"
95 965 "Phoebe"
Past
91 244 "Greeny" sold after the electrical system caught fire
88 245 "Margit" sold
93 244 completely disassembled - It died, so many of its parts could help others live.
97 855 T5
97 855 NA
RickATL is offline   Reply With Quote
Old 09-12-2022, 11:10 AM   #14
Murploid1
Murploid1's Avatar
In which case where can I purchase the tools? Or is anyone willing to sell?
Old 09-12-2022, 01:21 PM   #15
9995036 and 9995037 list as still available from Volvo. You can also try Baum Tools and ZDMak tools. They used to get Volvo special tools. The price really isn't much more than I paid 20 years ago.
Old 09-12-2022, 04:15 PM   #16
The Librarian
I checked with the dealer and they said 9995036 is available to order and 9995037 is on backorder.
The Volvo special tools website doesn't list 9995036. The one that's available may be the last one.
That said, I have a set that I'd rent out.
Old 09-12-2022, 04:59 PM   #17
Murploid1
Murploid1's Avatar
I have this on order, hoping that it does the trick..
https://www.amazon.com/dp/B09V4ZT1TP...NsaWNrPXRydWU=
If not then may take you up on the offer to pay to borrow your Volvo tools!
Old 09-12-2022, 05:23 PM   #18
hessam69
Can something be made or modified to work?
Old 09-12-2022, 07:04 PM   #19
Radtap
Radtap's Avatar
Did you read the rest of the thread?
Old 09-15-2022, 05:15 PM   #20
Murploid1
Murploid1's Avatar
Update is that the tools I bought from Amazon did the job.
Actually, the lisle kit I also bought would also have worked just fine.
Thanks for everyone's input
Old 09-15-2022, 05:20 PM   #21
Glad you got that hardware tight. Did the clunk go away?
Old 09-15-2022, 10:58 PM   #22
Murploid1
Murploid1's Avatar
Yes - clunk is gone. Nut was pretty loose.
Drives better too!
