Old 11-19-2021, 09:12 PM   #101
dandeluca
Originally Posted by dl242gt View Post
I have the rear main seal tool if you want to scan mine.
I will have to pay you a visit soon, it won't take me long to model the tool.
If anyone need them I modeled some center caps to use with Aries and a 240. I would have to dig up the files.
dandeluca is offline   Reply With Quote
Old 11-19-2021, 09:16 PM   #102
Old and boxy but good.
Yes, I really like those center caps. Well done!
Old 12-13-2021, 02:38 AM   #103
propav8r
F*ck Edgar
propav8r's Avatar
Hopefully the test print works out.
Originally Posted by 1968 volvo View Post
Tb's ot is a great place full of happy people who want to be your friend. The content of ot is always wholesome and no one ever gets angry or upset. Ever.
My Project
K-Jet to Megasquirt Article
Old 12-17-2021, 01:12 PM   #104
spock345
spock345's Avatar
Drop in aftermarket gauge cluster for an Amazon. Fits 1/2" indicator lights, 85mm and 52mm gauges. It sticks up farther than the stock cluster so it requires a new dash pad. I'm working on a pattern using a sheet of 1/2" upholstery foam, spray glue, and some marine vinyl.
The little holes in the middle are for some little plastic "staples" I use to hold multi-piece prints together. They do mean cutting off excess and sanding the surface smooth.
My printer refuses to do large ABS prints cleanly and I am waiting on ASA filament. So I am waiting on a printing service to finish up the final prototypes.
I'll upload some files once I confirm the final product works. I've got an earlier iteration in my car right now but the bottom was a few millimeters too narrow to take up the gaps between the metal dash and instrument cluster.
1998 S70, grandma-mobile
Old 12-17-2021, 01:19 PM   #105
rearwheelpeel
Slow Learner
rearwheelpeel's Avatar
I have a set of the clips for securing a rear louvre to a 240. Im trying to find someone locally to reproduce them so I can offer them to people here who may not want to buy them online elsewhere….
rearwheelpeel is offline   Reply With Quote
Old 01-27-2022, 12:02 AM   #106
spock345
spock345's Avatar
So if you are printing ASA or ABS filament for heat or UV resistance (say if you want a part to survive in the engine bay or on the dash) it can be tricky because it warps badly. Part of this is heat, the other is bed adhesion.
I've been playing with different configurations and I've finally got some larger pieces to not warp. I got this to work with a PEI sheet for the build surface, 100 celsius bed temp, and a cheap enclosure.
Just thought I'd share.
Old 02-07-2022, 11:37 AM   #107
spock345
spock345's Avatar
Just printed some door handles for my Amazon. The original ones had the foam/vinyl shrink and separate from the metal frame. These fit rather nicely. It is a really long print though. Took 17 hours for one handle. Although I had it set to a rather small layer height.
https://www.prusaprinters.org/prints...r-handle/files
Old 02-18-2022, 12:35 PM   #108
76RA24
https://www.thingiverse.com/thing:4588257
Anyone got the measurements for the shifter cage bushings?
Pete
76RA24 is offline   Reply With Quote
Old 03-15-2022, 04:46 PM   #109
76RA24
got one bushing out.
sort of in one piece.
Steel insert.
shifter bracket hole
printing some mockup PETG might get them installed to test this week. made in two parts to avoid supports.
pete
Old 03-15-2022, 07:09 PM   #110
Steel insert.
pete
Do you think PETG will have enough temp resistance for this application?
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 03-16-2022, 11:38 AM   #111
76RA24
it can handle the temp and the oil, not sure how it will effect the shifting... if I use the rigid PETG bushing.
I have TPU, but was feeling to lazy to change it out.
mucked up on my model anyways... tweaked it this morning again.
re printed... seems good when measured to the manky old rubber
real test when i pull the shifter frame and test fit later this afternoon.
Old 03-17-2022, 10:58 AM   #112
76RA24
https://www.thingiverse.com/thing:5320747
Old 05-30-2022, 03:22 PM   #113
Quoting post from VolvoLatam. Volvo 240 Center Console Panel Clip Fastener
https://www.ebay.com/itm/37382853272...oAAOSwfRhhumhu
don't have the pn, are these available new?
This would be a perfect part to 3d print. Don't ya think?
Old 06-25-2022, 05:55 PM   #114
johfraser
Alloy center caps
Sedan rear shelf vent panel (perhaps in pieces that can be put together)
Shift knob inserts
Old 06-26-2022, 12:42 AM   #115
MasterCylinder
What a lovely day!
MasterCylinder's Avatar
Location: The Fred Durst Society of the Humanities and Arts
I just picked up an ender 3 pro. Looking to work on some things.
Would Blender be recommended for doing the 3d models over, say, Fusion360?
BTW MicroCenter has a coupon you can get 100$ off if you're a new customer. You have to go in person though.
Originally Posted by CAPT_BLOTTO View Post
Wait. T-5 to T5? You can't do that. That's like against the rules.
'90 745ti '02 WRX Wagon '81 Corolla SR5
Master Cylinder Music
MasterCylinder is offline   Reply With Quote
Old 06-28-2022, 10:39 AM   #116
76RA24
blender I belive is for more sculpting than part design, could work though.
Fusion 360 is pretty good, with the free version.
FreeCAD I have made some things... Fusion was easier, but I think that was just more seat time in fusion vs freecad
Pete
Old 06-28-2022, 11:45 AM   #117
HiSPL
Fanking Champion 1993
HiSPL's Avatar
Blender can be used for 3d printing pretty well. If you already know how to use Blender or are a 3d artist in general it's probably the best choice since you'll already know how to use it.
https://www.youtube.com/watch?v=HqDnLg3o9WE
If however you are learning the software from scratch I would recommend using something like Fusion360 or other CAD programs. You'll get better more repeatable results using CAD, and a lot more support is out there.
Beets taste like buttfeet.
Originally Posted by 240 240 View Post
water-cooled VW owners can't even tell you the flavor of Cheetos they ate last night.
Originally Posted by Lando
96 960 (rotted)
88 244
06 XC90 V8
03 V70(crashed)
92 745 Turbo
Old 07-02-2022, 03:35 PM   #118
The handle for the rear seatback release on wagons would be a great part to repop. Last time I bought one it was $50 and only in black. Volvo will probably discontinue it in the near future and there are lots of wagons still rolling.
Old 09-17-2022, 10:14 PM   #119
HiSPL
HiSPL's Avatar
So I'm doing stuff.
Those 4 at the top don't fit. Finally got one that does fit, but I need to tweak it one more time for a better fit for both sockets. They are keyed slightly differently, but I'm making the plate where it fits both.
First fitted part!
Will fit the 1156 and 1157 sockets I bought from superbrightleds.com. It's where I got the lamps too and they are great!
Old 09-18-2022, 11:31 AM   #120
esmth
i like where this is going
1991 244 LH3.1 M46 402k miles
Old 09-18-2022, 11:57 AM   #121
white855T
Originally Posted by HiSPL View Post
So I'm doing stuff.
First fitted part!
For taillights or what? Looks super interesting.
Old 09-18-2022, 12:03 PM   #122
HiSPL
HiSPL's Avatar
Yep. The idea is to have a way to use new 1157/1156 sockets on your old tail light housings. This lets you run all the nice big modern LED bulbs.
I ordered some high temp PLA+ last night. As soon as that comes in I'll make a full set and glue them on to my tail lights and we'll see how well it works out. There is plenty of room for the bulbs and they are nice and bright!
The other bonus is that this lets you convert as many red lenses as you want to be running and brake lights. Even the fog lens can be used as a run/brake.
