Old 09-21-2022, 04:25 PM   #101
TheMenaceSD
Yea, I've found them just need to wait till I get paid. Since this is a project car and not my daily I have funds set aside each check for parts and such. Last check was gone with fluids and other replacement parts. Just need to wait till the next round and grab the gasket.
TheMenaceSD is offline   Reply With Quote
Old 09-23-2022, 01:34 PM   #102
TheMenaceSD
New head gasket it on, will start the reassembly and checking valve clearance.
Old 09-23-2022, 05:00 PM   #103
TheMenaceSD
Quick question regarding the guide pin on the camshaft. Is it supposed to need a hammer or mallet to install or should you be able to push it in by hand?
Old 09-23-2022, 05:10 PM   #104
white855T
You have to tap it in. Did you get the ipd pin?
Old 09-23-2022, 05:25 PM   #105
TheMenaceSD
I did, but I didn't have to tap it in. I was able to just press the pin in by hand without much resistance.
Old 09-26-2022, 01:25 PM   #106
TheMenaceSD
Small update, I measured the valve clearance and needed to order a couple shims that I didn't have. When I get back from vacation I will have everything ready to finalize the build and check to see if it starts.
