Old 09-12-2022, 02:06 PM   #1
VolvoLatAm
Default Some hose clamps Volvo utilized are great
I researched the brand of hose clamps used on my 82' eurospec 244--AWAB
they really are marine grade and well built--never seen a speck of rust on them:
https://www.practical-sailor.com/sys...long-term-test
another article:
https://www.practical-sailor.com/sys...el-hose-clamps
Did these come on the American market cars as well?
VolvoLatAm is online now   Reply With Quote
Old 09-12-2022, 03:02 PM   #2
Old and boxy but good.
ABA clamps are the version volvo uses. I've seen rust on them being up here where the brine rules the winter roads. But even rusty once you spray with a bit of penetrating oil they usually work fine. I've only had them fail from being overtightened.
Domestic cars have always used the worm drive clamps that gouge into the rubber hose from overtightening. Maybe some other Euro car makes use the good ABA clamps but I don't know. Porsche maybe?
Old 09-12-2022, 03:19 PM   #3
dorvin
idunno
dorvin's Avatar
I've gotten into the habit of having various ABA sizes on hand, they're excellent clamps.
Also, not sure if they were replaced by a previous owner, but I pulled AWAB clamps from my 850 that while they looked like garbage, they cleaned up and operated without issue.
'77 Oldsmobile Cutlass Supreme
'85 Cadillac Eldorado
'91 Volvo 740
'93 Volvo 240 - 683/1600
'97 Volvo 850 T5
'12 Volvo S60 T5
dorvin is online now   Reply With Quote
Old 09-12-2022, 04:07 PM   #4
Khrrck
Professional Amateur
I always appreciate the ones which have embossed slots for the gear engagement rather than punched holes. Chews up the hose less when tight.
'87 240 budget wagon. Sadly departed.
'88 240 eggshell wagon.
Old 09-13-2022, 09:35 AM   #5
Kjets On a Plane
Kjets On a Plane's Avatar
They’re decent?
MBZ have stainless w/nice rolled edge, but the screw itself is even on those mild if JY shopping but the post chrysler MBZ aren’t as good as the older style and finding MBZ w/7mm screws for your 7mm driver to match the rest of your Volvo & clamps in the cabin on the heater core & valve is a challenge for the anal/picky?
& my picquic super-8 multi screwdriver w/mariner anti-corrosion bits, I have to install the alternate sleeve for 7mm (larger than 1/4”, but smaller than 5/16” on the sleeve it comes with?) or use the 1/4” nut driver w/a socket which means not having it loaded and ready to go in the multi (tho you can use the flat/blade slot / similar but I prefer to use the 7mm hex…)
No big deal on the mild cad plated screw if you remove the screw and coat it in super thick grease (don’t get any grease that might dissolve rubber on on the hoses themselves!).
Idk who would have a corrosion resistant military grade inconel screw on a hose clamp…we can only dream to actually materially benefit a little more as mere peons from the ~$786billlion (as of ~5 years ago/budget that somehow never shrinks?) military budget a bit more tangibly?
Short of fancy t-bolt clamps, haven’t found anything better than junkyard -‘95 pre-Chrysler MBZ hose clamps for automotive and even the marine grade don’t match the rest of the Volvo great?
The MBZ the band is a little narrower and threads are softer/smaller being stainless so don’t man handle or over tighten them for both the long long term health of the hose & clamp?
How PSI a stock can support?
Always Be Crushing!
Old 09-13-2022, 10:05 AM   #6
culberro
culberro's Avatar
The OE hose clamps are OK. They’re too stiff to seal well in some applications, and when they get crusty it’s easy to strip them out.
I just buy these from McMaster, choose the grade of SS you want and rock on. I really like them on intercooler and turbo plumbing, 30psi + proper beaded tubes = no connections blowing apart. 4 sizes will cover most volvo engine bays and leave you with some spares as well. I keep a spare 7mm nut-driver in the car, which you can get from McMaster for less than $10.
https://www.mcmaster.com/hose-clamps...se-and-tube-8/
Head work: https://forums.turbobricks.com/showthread.php?t=349975
Temp Sender Adapters: https://forums.turbobricks.com/showthread.php?t=348169
Old 09-13-2022, 03:18 PM   #7
Kjets On a Plane
I have a giant jar of junkyard MBZ SS and just double up the clamps on the intercooler hoses…
…agreed that the Volvo clamps are a bit wide and stiff snd the hoses can squirm out from under them…
But I have more just school of hard knocks than insider industry knowledge or formal education & ‘do no harm’ w/more time than money, or did in years past and hate buying anything new If I don’t have to?
That said, I’d do what cullberro suggests to nail (clamp?) stuff down?
The picquic bits snap in the drill with the wobble or little mini-screw gun to wind them down nicely with some grease or anti-seize on the screw threads…
…power tools are faster winding on flanged 6-pt hex screws, but feeling stuff & verifying proper smooth threading winding it down slow & being gentle is important too if it’s your own car and you want to keep it 50,000 years or so & as close to factory as possible without getting stranded/ having unexpected unplanned ‘issues?’
Old 09-13-2022, 03:35 PM   #8
propav8r
F*ck Edgar
propav8r's Avatar
This guy did a rapid-fire test of a lot of different styles.
I've also found the Gates Power-Grip heat shrink clamps to be super useful.
Originally Posted by 1968 volvo View Post
Tb's ot is a great place full of happy people who want to be your friend. The content of ot is always wholesome and no one ever gets angry or upset. Ever.
My Project
K-Jet to Megasquirt Article
Old 09-13-2022, 11:26 PM   #9
culberro
culberro's Avatar
I've always wanted to try those...
Old 09-14-2022, 11:56 AM   #10
When I buy the clamps all the way on the right in the video for the air handling turbo pipes. The shop told me about the Gates heat shrink clamps. I didn't try them but they seem like a great product if you have the room to get all around them with the heat source.
Old 09-14-2022, 11:30 PM   #11
Harry Tuttle
The ABA clamps supplied on US 240's are very fine, but are made of plated steel, not stainless. The very same clamp is available from marine suppliers, such as Defender, in 316 stainless.
For a history of hose clamps, prominently featuring ABA, check this article. If you scroll down, there is a sidebar all about how these clamps were invented in Sweden.
Originally Posted by sbabbs
just gutless low compression k-junk
Old 09-15-2022, 01:03 AM   #12
redblockpowered
mails files to people
redblockpowered's Avatar
https://belmetric.com/
Bookmark this. The owners have some sweet Unimogs too.
I sell chips for LH 2.4!
If you live in the Northeast US, I'll drive to you and tune your LH 2.4 car!
Old 09-15-2022, 05:28 PM   #13
I second the Belmetric suggestion. They have quality hardware of all types including hard to find items.
