Old 03-30-2021, 02:30 PM   #1
grcamna5
Default 87' 240 key switch position II:will it discharge ?
Hi,I just joined,I'm Bill.
I want to hook-up a solar battery trickle charger(any recommendations for a small solar trickle charger/pulse solar trickle?)to my cigarette lighter socket.Can I turn the key switch to the 1st click II position for accessories w/o turning on any accessories and then connect a solar battery trickle charger on the dash and leave it parked like that without discharging the battery ?
This is just to maintain the battery to retard sulphation.
thanks,Bill
grcamna5 is offline   Reply With Quote
Old 03-30-2021, 03:31 PM   #2
I am pretty sure the blower motor runs in the accessory position. I don't have a 240 nearby to check.
Old 03-30-2021, 03:40 PM   #3
Khrrck
Professional Amateur
My '87 will run the blower with key in any position other than off. However I don't have the AC blower thing so turning off the blower switch should stop it.
'87 240 budget wagon.
Old 03-30-2021, 04:16 PM   #4
grcamna5
Yes,I keep the blower switch off and can't detect any other power-on accessory with the key switch in the II position.
Old 03-30-2021, 03:39 PM   #5
Khrrck
It will vary based on how much power your charger generates, what accessories your particular car is equipped with, and how bad a shape your wiring is in after 35 years.
You could, as an alternative, re-wire the lighter socket to be always hot and then charge with the key off. Or: add one of these behind the dash or inside the glovebox and wire to be always hot (https://www.amazon.com/SMAKN-Cigaret.../dp/B074CT5CSN)
Either way make sure to do proper wiring connections - solder and shrinkwrap or good crimps - and make sure it is fused! Your charger may only generate a couple amps but if it gets backfed from the battery or alternator you don't want anything dodgy or flammable going on.
Old 03-30-2021, 04:18 PM   #6
grcamna5
thanks Khrrck.
The solar charger I just ordered claims to make 5 watts.
Old 03-30-2021, 04:32 PM   #7
Khrrck
Originally Posted by grcamna5 View Post
thanks Khrrck.
5 watts or 5 amps? 5W at 12V isn't much!
In either case I would not recommend the key-on solution for long term storage, simply because it involves leaving the key in the car! (Cylinder will not release the key until car is turned off...)
Old 03-30-2021, 05:14 PM   #8
grcamna5
Yes, 5wts.,just a charge maintainer to keep the battery from sulphating,hopefully it'll be just enough.I'd like to get a solar 'pulse' charger,if they make one.I have a valet key I could leave in it while keeping my main ignition key with me,car locked.I park it right within sight down stairs from my apartment.
Old 03-31-2021, 12:45 AM   #9
MasterBlaster
MasterBlaster's Avatar
The only thing the valet key doesn't do is open the trunk and glove box.
It still opens the doors, and lets the crackhead drive your car away (after he smashes the window while you're sleeping and can't hear).
1990 740GL
517,000 km so far...
Old 03-30-2021, 03:48 PM   #10
nel621
I want to hook-up a solar battery trickle charger(any recommendations for a small solar trickle charger/pulse solar trickle?)to my cigarette lighter socket.Can I turn the key switch to the 1st click II position for accessories w/o turning on any accessories and then connect a solar battery trickle charger on the dash and leave it parked like that without discharging the battery ? thanks,Bill
Why? Are you going to leave it parked long term? Just disconnect the battery.
Old 03-30-2021, 03:51 PM   #11
Khrrck
They do make battery isolator switches that clamp between the cable and battery. Easy to install and toggle.
Old 03-30-2021, 04:13 PM   #12
grcamna5
I only run the car every couple months and I want to maintain the battery to keep it from getting below the voltage to where it starts to sulphate. thanks,Bill
Old 03-30-2021, 09:31 PM   #13
nel621
Why not disconnect the battery and then run wires from battery to solar charger. No keys in car.
Old 03-30-2021, 09:59 PM   #14
You can still find a copy of the '87 wiring greenbook (TP31054-1) here
I'd get one of the ebay fused cigarette lighter socket kits, mount it in one of the dash gauge blanking plates, or a switch block-off plate if it will fit, and wire it into the fuse panel. Look in the greenbook on page ~3 to see what fuses are live all the time, then find an unused tab on one of those to wire into. Check with a meter just to make sure the diagram matches your car.
Old 03-31-2021, 01:57 AM   #15
John242Ti
LH-Jet & Carb Free Zone
John242Ti's Avatar
To expand on what nel621 is suggesting, used one of those eBay fused lighter sockets wired directly to the battery. Then, on the negative terminal, install one of those battery shut off terminals. Make sure that the ground wire is connected to the clamp side of the shut off terminal. When the car's parked, unscrew the knob to disconnect the battery from the car's electrical system, then plug your solar charger into the newly added lighter socket, leaving it on the dash.
That way, no keys are needed, and the battery will keep its charge longer, since the charger won't be fighting any parasitic drains that may appear over the next few years, like they typically do on redblock cars.
@john242ti on IG
Old 03-31-2021, 02:25 AM   #16
Khrrck
Definitely this. Don't get your car stolen! Insurance usually doesn't cover theft if key was in the ignition, either.
Old 04-01-2021, 05:32 PM   #17
grcamna5
Thanks folks.I'll set something up as you described.I can install some wires to hook-up the solar charger direct and leave the key out of the ignition so I don't need to worry about theft.
That battery disconnect seems a good idea also as I don't want any extra draw on my system.Do you think they make something that I can install inline on my original negative- wire,kind of like a toggle switch,where I cut through the original cable and can turn it on and off ? thanks,Bill
Old 04-01-2021, 06:03 PM   #18
DD Ranch
DD Ranch's Avatar
IPD Battery Disconnect Switch
Florida Chapter VCOA
DD Ranch is offline   Reply With Quote
Old 04-01-2021, 07:27 PM   #19
nel621
You will need to isolate the battery from the entire car. The clock and computer will have a draw.
Old 04-02-2021, 01:28 AM   #20
grcamna5
Ok,thanks.
Old 04-02-2021, 11:25 AM   #21
grcamna5
I remember having that ignition cut-off on the negative post of my restored silver 87' 240DL I used to own:it was totaled back in 01' where I used to live on Cape Cod,I may have saved it(somewhere in storage..)but no matter.I just ordered it from IPD,they are a great resource,it's been a while since I've ordered,updated my info.
thanks for the link 'DD Ranch'.
