View Poll Results: What color for my Titan wheels?
Flat black 7 58.33%
Silver 4 33.33%
White 1 8.33%
Voters: 12. You may not vote on this poll
Old 12-31-2013, 11:58 AM   #751
Roy 940
Originally Posted by MadDog_945 View Post
Regarding your car pulls great and greater posts, you should smash the 1000 hp wall soon ;)
It's done... I'm looking for the 1100 HP now...
project Blue is Better
http://forums.turbobricks.com/showthread.php?t=247082
Roy 940 is offline   Reply With Quote
Old 01-01-2014, 12:21 PM   #752
REDBLOCK
REDBLOCK's Avatar
Why Propous? Maybe some classic rims like Polaris?
REDBLOCK is offline   Reply With Quote
Old 01-01-2014, 01:11 PM   #753
Roy 940
Because I prefer the BBS LM look over the Polaris...but they're nearly impossible to find here...
Old 01-01-2014, 02:21 PM   #754
REDBLOCK
REDBLOCK's Avatar
Polaris or Propus? I think i can find Propus in Poland, my Polaris wheels maybe tomorow on sale.
When we see the dyno results?
Old 01-01-2014, 05:37 PM   #755
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Look for BB5 LM ;)
Old 01-01-2014, 08:54 PM   #756
Roy 940
The Propus are BBS LM like
I've to call again the dyno shop, but not before 06.01.2014... It's very uncommon to dyno a car here, that's why I spend a lot of time to find one dyno shop here... It's a bad country about car mod...
Old 01-03-2014, 09:19 AM   #757
Roy 940
I'm hesitating now between this :
http://www.google.ch/search?q=infiny...ml%3B600%3B600
And this :
http://www.google.ch/search?client=s...ml%3B357%3B345
The biggest advantage of the Team Dynamics is the weight : they're 2 kg (per wheel) lighter then the Infiny!
Old 01-05-2014, 07:12 PM   #758
Roy 940
I'll go with this one :
Old 01-11-2014, 07:22 AM   #759
Roy 940
Rims ordered!
Old 01-11-2014, 07:38 AM   #760
murddraals
murddraals's Avatar
Location: Latvia (not too far from the Moose Motherland)
Congratulations!
murddraals is offline   Reply With Quote
Old 01-11-2014, 01:55 PM   #761
Mrkyosho
Mrkyosho's Avatar
Rims ordered!
Where did you order?
1983 244 B21A long term project
1988 745 Turbo DD
1995 945
Mrkyosho is offline   Reply With Quote
Old 01-11-2014, 02:05 PM   #762
Roy 940
Originally Posted by murddraals View Post
Congratulations!
Thanks!
Old 01-11-2014, 02:06 PM   #763
Roy 940
Here : http://www.driftshop.fr/
Old 01-11-2014, 02:31 PM   #764
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Omg... French is such a pita... ;)
What et and what price?
Old 01-11-2014, 06:03 PM   #765
Roy 940
No no, french is so easy...
ET 42 + 25mm of spacer in the front and 28mm in the rear.
Price is 600 Euro w/o VAT.
Old 01-13-2014, 05:44 PM   #766
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
No it isnt... :b
And those rimpz are killers.. Like bbs lm bam!
Old 01-13-2014, 06:52 PM   #767
Roy 940
No it isnt... :b
Thanks! I'm very excited to see it with my own eyes!
Old 01-15-2014, 01:11 PM   #768
HansW
HansW's Avatar
Hi
Haven't been doing much in terms of car, but got the following idea:
I have the type with only the intank pump, -- and for better flow i am toying with the idea to put a 044 Bosch in the line.
I thought to position it in the engine compartment lower left side, -- plenty of space there.
I even was thinking to only have it turned on when the throttle body sensor opens the second switch (more than 1/2), -- Now what are the thoughts on that?
940 classic Cd 1997
B230FT / M90L
530 head planed, KG 2T cam
Head gasket: Elring standard (Mls 0.35 was too tight, -- piston- head contact),
1041 axle 3.74, M90
15G at 0,85 bar
3" turbo back JT-superflow
3" Amm. + 42lbs injectors
STONI chips in 984 ecu and 167 EZK
Bosch WR5 DC+ (+15)
HansW is offline   Reply With Quote
Old 01-16-2014, 05:46 PM   #769
Roy 940
I don't see the advantage of your idea (even if I like it)...? Why to don't use the 044 always?
Old 01-16-2014, 06:36 PM   #770
HansW
HansW's Avatar
the cars from 95 on only have an intank pump, and the crate and hollow under the car is changed. -- So that is my current set-up.
It was simple with the older design-- just replace the main fuel pump. But it should work very well, considering having the big intank pump to feed the 044. Personally, i prefer the location in the engine compartment, -- just gathering connectors brackets etc. and then at some time in the future go ahead and try, --
cheers, Hans
Old 02-13-2014, 09:57 AM   #771
Roy 940
Small update :
I've installed today a new set of injectors (brand new Bosch 4 jet 550's) and I've to let the car re-learn it. I hope it'll solve my AFR issue @ WOT past 6K.
My new summer wheels will be installed soon also (I hope at the end of february), and I'll post pics as soon as it's done.
Other then that, I've played (again...) with my cam timing : it's now retarded (4°) and it seems to be great like that!
Again, I'll let my car learn those mods and I'll report the result here...
Old 02-15-2014, 02:23 PM   #772
DET17
Reformed SAABaholic
Take care in the rear. I run the Propus et43, and originally had 32mm spacers back there...no good, couldn't stop my tires from scrubbing. I ended up with 25mm spacers all around. Net ET I believe is 18.....Maddog I believe also recommended around this setting.
Looking forward to see those rims on die Vaggen!
Old 02-15-2014, 03:47 PM   #773
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Yep, with et18 its easy to level it out with an adjustable panhard...
Old 02-15-2014, 04:21 PM   #774
Roy 940
I'll modify my front spacers from 25mm to 22mm, and I'll see if it'll rub or not on the rear...
But thanks for your advice!
Old 02-17-2014, 02:16 PM   #775
Roy 940
Ok, I've done some test with my new injectors...
I was wrong since the beginning of my project!!! What a gain with big injectors installed!!! My car pulls hard now!
