Old 02-05-2014, 04:46 PM   #1
Jack
junkman
Jack's Avatar
Default 16v head block choices - what to build?
I have a 16v head burning a hole in my wallet and on my shelf. I been thinking that I eventually might trow it into my 245.
which block would you put it into and why
I have:
- b23 engine complete with original 54k miles
- b21ft block with 150k miles - head is off and everything seems to be ok
- b230 (least likely candidate) original still in car almost 300k burns zero oil
also have a 15g matted to a 90 mani
discuss
I love you even more Jack.
Old 02-05-2014, 04:49 PM   #2
B23 seems like the pick of the litter there. Build it while the B230 keeps the car rolling around for now.
Get that valve relief cutting kit and keep the B23 together.
Old 02-05-2014, 04:50 PM   #3
Jack
junkman
Jack's Avatar
^ my thoughts also
but why not the b21ft? especially if I turbo charge
Old 02-05-2014, 04:55 PM   #4
huskybruiserjr
well is this a fun daily car, or street/strip car?
huskybruiserjr is offline   Reply With Quote
Old 02-05-2014, 05:01 PM   #5
Jack
junkman
Jack's Avatar
car will be/is used for daily.
Old 02-05-2014, 05:05 PM   #6
John V, outside agitator
Originally Posted by jack View Post
^ my thoughts also
You'd get the great benefits of the chamber design but the intake valves are ssssssooooooooooooooooooooooooooooooo close to the edge of the cylinder that you will valve the cylinders 'shrouding" the valves...
Volvo when they did B204s at 88.5mm bore reduced valve size in those heads.. B21 is 92mm but those valve are right at the edge...
Blocks are easy and cheap, why not just get a B23 or B230 and be done?
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
— Don Marquis
Old 02-05-2014, 05:06 PM   #7
Yeah, where's the pic of a 16V head sitting atop a B21 bore?
To the googles!
Old 02-05-2014, 05:08 PM   #8
As JohnV was saying, there's really no way for air to flow around that outer edge of the valves when the cylinder wall is *right there*. So you don't get all the flow the 16V was supposed to give you.
Old 02-05-2014, 05:11 PM   #9
Jack
junkman
Jack's Avatar
I have both see first post
now I understand why not the b21ft
Old 02-05-2014, 05:56 PM   #10
huskybruiserjr
thats an interesting way to show what he meant! very cool yet informative pic! i was gonna say b23 block just for the "no replacement for displacement" argument.
Old 02-05-2014, 06:00 PM   #11
but that ol' saying is wrong.
The replacement for displacement is BOOST (more CFM, or CC or whatever unit of VOLUME of air literally PUMPED in to the volume the motor would do normally..---Just how did little 1500 F1 cars make a bazillion hp? LOADSA boost AND lots of revs
Old 02-05-2014, 06:03 PM   #12
huskybruiserjr
and pneumatically powered valves!
Old 02-06-2014, 06:02 AM   #13
GreatDaneShane
GreatDaneShane's Avatar
b23/21ft are going to require a roundtooth crank gear from knox motorsports, pretty sure its 175$ Just pull the b230 head, cut the reliefs, and throw the 16v head on it. (Assuming you have all of the parts you'll need.)
GreatDaneShane is offline   Reply With Quote
Old 02-06-2014, 12:16 PM   #14
Jack
junkman
Jack's Avatar
I pulled the crank gear from the "donor" b234 engine
Old 02-06-2014, 01:23 PM   #15
DET17
Reformed SAABaholic
Pretty sure the crank snout/gear are specific to the B21/B23 forged (almost always) crank. The B230 has a different size snout where the gear mounts. TB lore has it that the B234 crank gear has a bad habit of disassembling itself under load.....hence the stronger versions.
I've got one of those KNOX or YF versions of that B23 crank gear.....if I can find it I will measure the ID. I've also got each version of the crank in my workshop, will check tonight if I remember...
Old 02-06-2014, 01:32 PM   #16
Lord_Athlon
300+ Clurb
Lord_Athlon's Avatar
Wont fit on a b21
Originally Posted by RvolvoR View Post
simple...just throw the redblock in the trash and install, well, almost anything modern
Yet Asher here went with...
Old 02-06-2014, 02:20 PM   #17
REDBLOCK
REDBLOCK's Avatar
jack buy B230F block, borrow this special tools to drill piston or buy forged rods from RSI- i think its easier, cheaper and more profi for the future.
REDBLOCK is offline   Reply With Quote
Old 02-06-2014, 02:33 PM   #18
Jack
junkman
Jack's Avatar
Originally Posted by Lord_Athlon View Post
Wont fit on a b21
established that I wont use a b21 engine
options are b23 or b230
Old 02-06-2014, 02:39 PM   #19
Jack
junkman
Jack's Avatar
forged rods ... I will do that.
will go with a late model b230f maybe ft because entire engine assemblies are only 150-170 by my house (used)
also I hate to get take apart the b23 since is such low miles engine
ps taking pictures right now
Old 02-06-2014, 02:45 PM   #20
cosbySweater
cosbySweater's Avatar
What platform is it going into? If 7/9 just use a b234f
1995 Porsche 993
2013 VW Passat TDI
cosbySweater is online now   Reply With Quote
Old 02-06-2014, 02:51 PM   #21
Jack
junkman
Jack's Avatar
no 7/9 series here
harder to find a b234f engine
Old 02-06-2014, 02:58 PM   #22
GreatDaneShane
the b23 crank is the same as the b21 crank, so you'll need a special crank gear.
Old 02-06-2014, 03:00 PM   #23
Jack
junkman
Jack's Avatar
lol
looks like its some b230 engine after all
Old 02-06-2014, 03:02 PM   #24
cosbySweater
I forgot what belt I believe it was something off a fiat, but I'm pretty positive someone on here did a 16v with a square tooth belt
Old 02-07-2014, 04:57 AM   #25
Jack
junkman
Jack's Avatar
hmm
shouldn't be to hard to find the correct belt - just count the number of teeth from round tooth and contact a belt manufacturer like Gates for the correct part#
