Old 03-21-2021, 07:26 PM   #1
Sketchysedan
Default Brake lights
I recently bought an ‘87 240 wagon. When I got it, only the high mount brake light worked, but that recently stopped working. I suspect it is the wiring in the hinges fraying for that one, but neither of the other brake lights work. I have verified voltage at the fuse board and pedal sensor, verified that the pedal sensor works, and swapped out for a known good bulb failure sensor from my ‘87 sedan. Brake lights are still not working, I am getting no voltage at the wire for brake lights in the rear of the car and I do not get a bulb failure warning light on the dash. Cruise control also stopped working the same day the third brake light stopped working, unsure if that could be related or not.
Sketchysedan is offline   Reply With Quote
Old 03-22-2021, 09:58 AM   #2
Beep beep zip tang
Try spinning the fuses.
Old 03-22-2021, 12:04 PM   #3
Khrrck
Professional Amateur
yeah, make sure you check both sides of the fuse for voltage.
Do you still have the big cylindrical bulb failure relay? Check on both sides of that. Common source of wiring death.
'87 240 budget wagon.
Old 03-22-2021, 12:59 PM   #4
Sketchysedan
Yeah I still have the relay. Is there a way to actually check it? And yes, I was getting power on both sides of the fuse
Old 03-22-2021, 03:16 PM   #5
You can test the bulb out sensor relay by using a test light. It just has various circuits connected to it with in and out locations. So when you hit the brake pedal. You should get voltage passing through from in to out for the brake lights. It would light the test light.
PS Open your hatch and look at the hinges. If you see wiring that is broken and split. Then you need the hinge wiring harness replaced or repaired. .
Old 03-22-2021, 03:32 PM   #6
Sketchysedan
Yeah all the wiring is cracked or broken in the hinges, the rear wiper and rear window defrost do not work, and I suspect that is why the 3rd brake light stopped. That shouldn’t have anything to do with the outer brake lights on the body not working right?
Old 03-22-2021, 03:55 PM   #7
Khrrck
No - IF it is not shorting to ground and blowing the brake light fuse. I suspect you would have noticed though.
Old 03-22-2021, 04:26 PM   #8
Sketchysedan
Yeah brake light fuse has been intact this whole time. I’ll try and check that bulb failure warning relay later tonight
Old 03-22-2021, 05:06 PM   #9
Khrrck
Are all other lights working? (turn signals, reverse lights, tail/running lights, single rear fog)
A couple other things you can check:
You can remove the spade connectors from the brake switch and short them together (careful not to short to ground on the nearby metal bracing - will pop fuse quickly!). Then check for voltage back at taillight assembly wires.
You can pull back the headliner in the rear corners and check for voltage to 3rd brake light - would at least indicate some wiring is good that far back.
Old 03-22-2021, 10:17 PM   #10
Sketchysedan
Yes, all other lights are working. The only thing is I think it has the wrong headlight relay as when I turn on the parking lights, the headlights come on. But yes, everything else works. And I tested the brake lamp switch with a multimeter, it opens/closes the circuit as it should. I have already tried connecting the two wires normally plugged into the switch together and still no brake lights or voltage. What’s especially weird is I am pretty sure I had the right rear brake light working intermittently.
Old 03-23-2021, 02:58 PM   #11
Definitely need to trace power with a test light. Check the input/output terminals on the bulb out relay. How do the bulbs look? Very often the gaskets on the lights leak and the water causes the bulbs to fail.
Old 03-25-2021, 03:47 PM   #12
Sketchysedan
Just checked out bulb failure relay. I’m getting 12v out of 4 of the pins with the brake pedal pressed down, and still no bulb out light on the dash. Where does the harness run in the car? Does it go straight from the bulb failure relay to the bulbs or does it pass through anywhere else I need to check?
Old 03-27-2021, 03:23 PM   #13
As far as I know. The wiring runs from the bulb failure sensor to the lights. Is there any voltage on the wiring at the back of the car?
