Old 03-08-2021, 04:07 PM   #1
Nickagriffin
Nickagriffin's Avatar
Default 1988 Volvo 240 No start
Hey all. Sorry for adding to the absurd amount of no start threads, but I'm stumped.
I picked up this LH2.2 245 a few months back and lately it has been taking a while to start. Today, it decided not to start at all. I jumped fuses 4 and 6 and heard the main pump, but no start. Tested the power to the in tank pump and it was good. Cleaned the terminals of the 25 amp fuse in the engine bay.
Eventually decided that it was probably spark, so pulled a plug and cranked, SOLID SPARK! Additionally, there was some fuel spraying out of the cylinder while I was cranking.
So it seems like there is spark at least for one plug, both fuel pumps working, fuel relay working
Any ideas???
1992 240 Sedan Project Car
1988 245 Daily
@turbobricknick on instagram
Nickagriffin is offline   Reply With Quote
Old 03-08-2021, 04:14 PM   #2
Nickagriffin
Also tried unplugging the maf, shifting into neutral and back into park, and unplugging and plugging back in the Hall sensor
edit: And I added another gallon of gas
Old 03-08-2021, 04:26 PM   #3
Disable injectors, clear flood, two long blasts of starting fluid into an open throttle, crank, it should run. Keep it running on short blasts of starting fluid. Then retry.
Click my sig
Old 03-08-2021, 04:39 PM   #4
With LH2.2 240 setup. You can get a spark on initial key crank. You have to make sure the spark is strong and continuous. Just turning the key off and on will make a spark. Another check is to use a noid light or your handy test light on an injector. No flickering means no injector pulse. That happens when there isn't a rpm signal to the ecu. Then it won't open the injectors.
Check fuel pump relay.
Old 03-08-2021, 07:55 PM   #5
Lazarus
Looks like an aftermarket timing belt (blue?). Be sure all the marks line up. Also be certain that your main vibration damper pulley is not worn out. The rubber core can let the timing slip. Have the valves been adjusted lately?
-L
Lazarus is offline   Reply With Quote
Old 03-08-2021, 08:51 PM   #6
Nickagriffin
Alright, so I fixed it, but I have no idea how. I followed ZVOLV's suggestions and cleared the cylinders, unplugged injector wires, and sprayed some starting fluid in the throttle body. I also replaced all 4 spark plugs with some NGK BP6's and did the rotor and cap. After doing all that it fired right up. Plugged all the injectors back in and tried that way and it kept running!
I guess it couldve been flooded, or maybe it was an intermittent spark problem.
Old 03-08-2021, 09:29 PM   #7
Nice! I had my 1991 740 Turbo sit for 2 months recently and it was the same scenario- pumps running, crank, spark, but no start. I think it may have lost fuel pressure prime, flooded, or weak compression. IDK.
Regardless, I used starting fluid and got it running and it ran ever since.
Old 03-09-2021, 04:12 PM   #8
Nickagriffin
Well I woke up this morning and went to start it, and it started, but it still takes forever to start. It also stumbles a bunch before it finally gets going. Any ideas?? I'm gonna put some seafoam in the tank and see if that does anything.
Every other 240 I've owned starts up really fast.
Old 03-09-2021, 07:20 PM   #9
Torn hose in the tank?
Old 03-09-2021, 08:52 PM   #10
Nickagriffin
I did just replace the in tank pump with the upgraded IPD one, maybe I did something wrong?
Old 03-11-2021, 12:14 PM   #11
philski o'flood
philski o'flood's Avatar
if the check valve on the main pump won't hold pressure it will take longer to start
Old 03-17-2021, 08:12 PM   #12
Nickagriffin
Well I seafoamed it through the gas and thought I had solved the issue but today it took a really long time to start up again. It seems like the gas takes forever to prime but once it's running, it seems to run just fine. Is that what would happen if the check valve was bad?
Old 03-18-2021, 11:19 AM   #13
philski o'flood
exactly what happened when mine was bad
when it's working it keeps the full pressure from the pump to the injectors
when it's not working takes a way long time to start but then runs fine
Old 03-18-2021, 02:51 PM   #14
Nickagriffin
Alright, I ordered a check valve and a fuel filter. I'll put them in and report back
Old 03-19-2021, 04:44 AM   #15
Otto Mattik
board member
Otto Mattik's Avatar
Kinda curious what if any effect the Seafoam had ? I'm guessing you know it's designed to help stabilize fuel, clean carbon deposits, etc..and if you the fuel is bad it typically will smell like varnish, and will need to be removed(ask me how I know).
Checkvalve serves to keep fuel from flowing back/help maintain pressure.
Old 03-19-2021, 03:08 PM   #16
Nickagriffin
The seafoam didn't really change anything, but I had some people suggest it so I thought I'd give it a shot. I was hoping that the injectors were gummed up and it would clear them up, but I don't think that was the issue.
Old 03-22-2021, 02:30 AM   #17
Otto Mattik
board member
If you have a way of checking the fuel pressure, you can test it, and then let it sit overnight and compare to see if it dropped.
Old 03-28-2021, 04:29 PM   #18
Nickagriffin
Just got the check valve put in on Friday, seems like that was the issue! Thanks everyone
Old 03-29-2021, 05:09 PM   #19
sheepbleat
Thanks for the update! Glad it worked out. Will remember this when I inevitably encounter the same issue.
Greg
My Feedback Thread
Old 03-29-2021, 05:51 PM   #20
Without measuring fuel pressure before and after, it really isn't a confirmed fix.
Old 03-30-2021, 11:03 PM   #21
Nickagriffin
True, but the part was cheap and I wanted to do the fuel filter anyways. I'll make sure to wake this thread back up if it happens again.
