Old 06-11-2020, 09:34 AM   #551
Swedbrick
Swedbrick's Avatar
Originally Posted by MadDog_945 View Post
does anyone know what the pink/black cable is for?
IIRC It's a part of the AC system, for the purple high pressure switch, could possibly also be towards the bumper outside temperature sensor, which were green blue in the looms I've thinned down.
Nice progress!
Swedbrick is online now   Reply With Quote
Old 07-20-2020, 02:09 AM   #552
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Thx !
Made some progress here and there..
Im just trying to figure out if i can use a BMW E39 Fuelfume Breatherbox instead of the OEM one, cause it is much more compact or if the valve is missing and i need a separate one or if im just uwsing the OEM box when i find a used one.
It is not far from its second first start up
Old 07-21-2020, 12:38 AM   #553
Finnish240
Finnish240's Avatar
I was planning to get one of those bodymount shifters, but ended up doing stock style shifter mount during m90 swap to my 240. Maybe some day if you get good results using one?
Volvo 240 GL - not so low, but yes.... it is slow
Finnish240 is offline   Reply With Quote
Old 07-21-2020, 02:35 PM   #554
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
it is awesome.. i found myself sitting in the car rocking through the gears making some turbowhistle and blowoff noises like a little child :D
it is pretty easy to adapt the oem shifterbag to fit it.. retropete send me the shifter to write a how to. 8t is pretty easy to install it and the gears kick in pretty tight
Old 07-21-2020, 02:48 PM   #555
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
found an oem fuelfume filter in my slaughterhorse ;) never saw that oem mountingbracket.. in my old car it was ziptied. seems it fits everything pretty well!
Old 07-27-2020, 06:44 AM   #556
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
- Driveshaft is in
- vacuum is fully done with a really nice vacuum block for small money
- fuelfume filter is also at its place and connected
- fuelsystem doublechecked for tight connections
- both front fender and firewallpanel installed and trimmed
- headlights installed
- passenger harness completed
- driverside wiringharness alomost completed -> it misses the starter and generator connections
- gearbox linkage secured with loctite
/edit
jeeeez.. the camera in my CAT S60 really gets ****tier every day...
Old 07-27-2020, 12:12 PM   #557
Old 07-28-2020, 08:32 AM   #558
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
I will try to use my better Digicam for further Pics.. that really looks not that good anymore ;)
Old 08-09-2020, 03:35 PM   #559
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
https://youtu.be/53VmuzdL564
It's alive!... ...again.. ;)
Old 08-15-2020, 04:45 AM   #560
Martin L.
Kombinationskraftwagen
Martin L.'s Avatar
IDKFA
Martin L. is offline   Reply With Quote
Old 08-17-2020, 05:04 AM   #561
JW240
All idiot, no savant
Nice!
Old 08-20-2020, 03:26 PM   #562
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
i have an errorcode 1-4-4 on port 6 of box A.. does anyone had tnis issue before? error occurs 3 secs after start and does not disappear until erasure. engine idles, and revs like a charm, unfortunately i connected 2 pins of box a while soldereing with shorting, dont know if the error was there before..
Old 08-20-2020, 04:07 PM   #563
Missing signal between LH2.4 and EZ116K. Check your wiring
Old 09-21-2020, 08:48 AM   #564
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Indeed it was the wiring. Got myself some really cool 8 pin AMP superseal like connectors and got the harness redone and repaired the rearbumper.. typical problem.. Aluminium on Steel and got some cocaine unter the Damper :D
The car saw sunlight leaving the garage on its own feet under own power.. that was a nice moment
Old 10-08-2020, 03:44 AM   #565
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
4 days ago i finished the interior just to find out i have a bad shortage which made the fuse 4 (brakes) blow off. all the interior is in pieces again to find that fault.. bummer..
Old 11-03-2020, 07:19 AM   #566
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
I managed to get my hands on some KZK-plates which allowed me to drive the car around for 5 days. Tried to get TüV.. the never ending Story remains :(
I needed to replace the RetroTurbo Gearbox mount with an OEM one. Nothing against The RetroTurbo one, but it made from PU and it is like the gearbox is mounted flush with the body. Everythings shakes and rattles.. .. it is not *bear*able ;) when driving around but the load changes with that really feel great, almost motorsportlike.
The car really felt great, all those bugs and features from the last drive and in that youtube video are gone and i believe it was the toasted connectors in the wiringharness/plugs. So always good to redo the connectors ;)
Some pics:
Infront of buddies house fetching him up for a ride
preparing the car for the ride (sry for quality)
trailering the car to TüV cause the apointment during those 5 days was cancelled due to corona ^^
Old 11-03-2020, 07:24 AM   #567
Martin L.
Martin L.'s Avatar
What ist the problem now? I thougt you specially made everything now according to the TÜV's whishes?
Old 11-03-2020, 07:34 AM   #568
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Yeah, the GTÜ which my buddy recommended me through a bit of "Vitamin B" was unable to accomodate a Turbo from an V70 and also the brakes...
My next try is the "real" TüV when this does not Work either i will try a local tunershop specialized for engineswaps and road legality
Old 03-28-2021, 10:25 AM   #569
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
so.. updates.. papers are on the way to get checked.. maybe i have TüV by next week :D
in the meantime i did some stuff, but not much...
And this is how it is waiting for it to be driven... uh.. i cant wait any longer..
Old 03-28-2021, 02:30 PM   #570
JerryJS8
der Junge
JerryJS8's Avatar
Ahhh, now I seez cam cover
When you going to drive down to normal Saxony and meet me for a little burning rubber?
- 1992 480 (Renault disaster)
- 1989 745 16v
- 1991 744 (SE) 16v Turbo
Old 04-21-2021, 03:13 PM   #571
JerryJS8
der Junge
JerryJS8's Avatar
Updates? Updates? Updates? Updates?
(I know there's something coming)
Old 04-22-2021, 04:53 AM   #572
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
:D
Old 05-01-2021, 11:24 AM   #573
Wilford Brimley
Is posting from the grave
Wilford Brimley's Avatar
That quad is dope
Deb the 940T Tina XC90 T5
Old 05-02-2021, 02:28 PM   #574
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Thx, wanted it in the style of my old Nato bitch
Old 05-04-2021, 02:33 PM   #575
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Started to part out the Slaughterhorse and scavanged some Plasticparts and the carpets to replace the broken ones in the 16v
Deciced to redo the whole interior cause i sourced a König seat with no holes for harness which i searched for years... (was sold with a Slalom racecar i accidentially bought :D )
My Luck was, my buddy wanted to help me out and he has one of these fancy active carpetcleaner hoovers... this thing is a beast
Also the Tornadogun really helps. the carpets look and smell as good as almost new
I really like how all the Leather, Carpet, Plastictrim and ceiling cleaning came out.. the car never looked as good as it does now being owned by me
I also ordered an HKS Mushroom Airfilter just for the swooosh jijijij :D Am creating an almost sealed box out of a BSR Airfilter Tray for the stealthyness
Oh.. i almost forgot.. i have TüV !! :D The journey of my life has come to an end.. made an appointment for registering the car as seasoncar, have to wait 2 more weeks but anyway.. Time in which i can do some last stuff
