Old 05-16-2021, 08:43 AM   #1
Jsegura525@aol.com
Default Rotted away door card bottoms... How to ...
Good morning chaps and chapettes....
I pulled the door cards on a 240 (1982) and there was over an inch of
dirt in the door and the door card lower 1/3 is rotted away. What have you
all used to remove and replace the rotten section?
Thanks in advance,
Joseph Segura
Jsegura525@aol.com is offline   Reply With Quote
Old 05-16-2021, 10:04 AM   #2
https://www.picknpull.com
how psi stock cna sprout?
Old 05-16-2021, 10:11 AM   #3
OldCarNewTricks
OldCarNewTricks's Avatar
Hard part is getting whatever you use to replace that bottom 1/3 joined with the main card. Then making it lay flat.
I asked a similar question recently: http://forums.turbobricks.com/showthread.php?t=360216
Old 05-16-2021, 11:02 AM   #4
hk 40
Banned
Photos please
hk 40 is offline   Reply With Quote
Old 05-16-2021, 11:17 AM   #5
OldCarNewTricks
Joseph, is your car a 2 or 4 door? It's much easier to find the 4 door panels at the picknpull as suggested by Redwood.
Old 05-16-2021, 11:51 AM   #6
There hasn't been a 242 in your JYs for 3 or 4 years now.
Old 05-16-2021, 01:19 PM   #7
Corey
Corey's Avatar
https://forums.tbforums.com/showthread.php?t=346785
sig pic
'81 242 turbo
Corey is offline   Reply With Quote
Old 05-16-2021, 01:22 PM   #8
OldCarNewTricks
Originally Posted by Corey View Post
Sweet! I'd like to do this but reuse the factory vinyl.
Old 05-16-2021, 03:56 PM   #9
nel621
How perfect does it need to be? You could replace the rotted section with some masonite board cut maybe 3 inches larger to overlap the top edge. Glue it with liquid nails , then attach your bottom upholstery. Take your time , don't forget the cutouts for the clips.
Old 05-16-2021, 06:26 PM   #10
OldCarNewTricks
That's not a bad idea. Could use foam to space the fabric out
Old 05-16-2021, 09:34 PM   #11
Ursan
Bored Member
Ursan's Avatar
I've used mesh and resin to do a halfway decent job. The hard part is keeping the skin taut while curing.
I made a jig not unlike a skin stretcher dryer that I learned to do in scouts using binder clips.
Originally Posted by 740freak View Post
how psi a stock can support?
Originally Posted by speedn_j View Post
So I’m a racist big deal who cares. Deal with it.
I admit I'm stupid...
1990 780t Kind of Modded 1994 945t Pegz, Tintz, Hidz.
"Rear Wheel Drive, the way God intended. If a car is being pulled from the front, doesn't that mean it's being towed?"
"Lister, you are a polyp on the anus of society." - A.J. Rimmer
Ursan is offline   Reply With Quote
Old 05-18-2021, 12:37 AM   #12
OldCarNewTricks
I'm intrigued! What did you use as the "backbone" of the stretcher? I was thinking that thin plywood in a similar shape as the damaged area might do okay?
Old 05-18-2021, 12:25 PM   #13
apachechef
Burnt Sierra Madre
uhr, did you put the lotion on the skin first?
Dammit, Lummert.
Old 05-19-2021, 10:44 AM   #14
Ursan
Bored Member
Ursan's Avatar
It was just 1x1 lumber in a frame about 8" larger all the way around. I also removed everything I could from the card. Once the resin hardened and the card was structural, I manually folded the vinyl back over the edges and glued them in place.
It looked like a murder scene from behind, but from the front, it wasn't bad and even better when it was mounted.
I even managed to re-create the tab holes by trimming plastic soda bottle caps and slipping them under the fabric and trimming them out with a Dremel.
All the lotion.
Old 05-20-2021, 08:24 PM   #15
Brontes II
Hardboard/High-Density Fiberboard (HDFB)/Masonite is very bendable when steamed or spot heated (i.e. with a heat gun). Both methods are used in model making, stage set design, and for things like custom molded pallet caps and inserts.
If it were me, and I was trying to reuse the original vinyl and otherwise keep things as factory-like as possible, I’d cut a new panel backing and make a press jig from plywood and/or aluminum to then work it into shape. Sealing it afterwards would probably be a good idea to stave off future rot.
I’ve been known to go a little overboard with this sort of thing though, so maybe that’s a somewhat excessive solution.
Newbie Lurker Since Oct 2007
Brontes II is offline   Reply With Quote
