Old 05-11-2021, 11:28 AM   #1
QisofrKuin
Default PRV B27F, just how bad is it?
Hey all,
I'm looking at a 1976 262 GL that supposedly was running well until the starter went out, so I won't be able to verify how well it runs. I know these engines are notoriously bad, but is it "never buy one if you want to have a daily driver" kind of bad? Will I be fixing this until one day it just throws a cam? Or is there some work I can do to keep it decent? I also have heard that people would scrap these 6-cyl. engines and just drop a redblock from some junked 240 in there, does anyone have an idea of the cost of such project? Is it a simple swap or a difficult one? I'm very fond of the two-door look of the 200 series, but they're hard to find down here in Texas and usually expensive, I feel like this may be rare chance to pick one up for 3k or less, but don't want to walk into a very expensive nightmare.
Thanks for your thoughts.
QisofrKuin is offline   Reply With Quote
Old 05-11-2021, 11:33 AM   #2
Run far run fast while you can.
how psi stock cna sprout?
Old 05-11-2021, 11:42 AM   #3
white855T
Originally Posted by QisofrKuin View Post
Hey all,
Unless you can get that 262 for $1000 or less, you'll already be in the hole. The paint is shot on that one. Interior is ratty. I would not recommend buying it. That car keeps getting passed around in Texas. No one is willing to do the work. You're looking at a complete restoration if you plan on engine swapping.
Old 05-11-2021, 11:47 AM   #4
QisofrKuin
Oh good you know the car. Well, not the news I was hoping for, but admittedly what I was expecting after all I've read about these. Thanks!
Old 05-12-2021, 08:53 AM   #5
nel621
Keep in mind that 262GL is more rare than the 262c.
Old 05-15-2021, 02:54 PM   #6
OldCarNewTricks
OldCarNewTricks's Avatar
You could always find a later PRV for it.
OldCarNewTricks is online now   Reply With Quote
Old 05-15-2021, 04:17 PM   #7
A B280F would be about as good as you get from Volvo.
Old 05-16-2021, 02:34 PM   #8
TestPoint
TestPoint's Avatar
Just my romantic thoughts on the the B27/28 PRV.
Owned one in the early 80's and loved it. More than adequate power and a respected engine of its time.
The principal issue with the PRV's was failure of the cam oiling capability in the early engines with the oil technology at the time. Later engines added additional oiling capabilities. Even later engines added balanced firing that did not exist on the early engines.
I have a '81 PRV with 25k miles on it and have confidence that with the use of full synthetic oil this engine will survive a very long time.
As time passed the Bosch K-jet fuel system issues further disparaged the value of this engine. Now, the cost of repair of K-jet fuel distributor and CPR further reduces the perceived value of a PVR unless it is attached to a car that has historic /financial value of its own.
Ford V8 Conversion Manual -
Old 05-16-2021, 03:07 PM   #9
OldCarNewTricks
I still think a V-6 from a newer car coupled to an electronic controlled auto trans would make for an amazing commuter 240.
Old 05-16-2021, 03:34 PM   #10
TestPoint
TestPoint's Avatar
I completely agree.
. . . unless it is attached to a car that has historic /financial value of its own.
Old 05-16-2021, 06:45 PM   #11
This is why I suggested the B280F. However, the Dodge Monaco and Eagle Premier did use larger and even more well designed versions of this engine. They are the ones John Lane uses to make his big power on the fire breathing dragon rally car.
Old 05-16-2021, 07:38 PM   #12
OldCarNewTricks
I would love to have one of those in my 242.
Old 05-16-2021, 07:42 PM   #13
shoestring
shoestring's Avatar
I believe a PRV holds the lap record for production-based engines at Circuit de la Sarthe.
Fact check: my error, it holds the SPEED RECORD.
So, there's some provenance in that.
Old 05-16-2021, 09:35 PM   #14
OldCarNewTricks
All the more reason to make my 242 into a faker 262.
