Old 01-03-2021, 08:07 PM   #526
LC4CARL
Aero challenged
LC4CARL's Avatar
Oh dear.
Awesome.
Love this build.
@PDXvolvo on IG
B21FT with a T3/T4, STS coil-overs, T5 trans.
Old 05-14-2021, 11:43 PM   #527
Cwazywazy
Single jingle
Cwazywazy's Avatar
Finally got around to sticking the oil cooler in while I was doing this years oil change. It's a snug fit, but it works.
I don't know what I have
Old 05-15-2021, 12:09 PM   #528
Jerd
Jerd's Avatar
I love this thread, great project. Glad your turbo hasn't fallen off again lol
Jerd is offline   Reply With Quote
Old 05-15-2021, 03:00 PM   #529
Cwazywazy
Single jingle
Cwazywazy's Avatar
I still check it every once in awhile lol, but it's been staying put.
Old 05-17-2021, 08:57 AM   #530
esmth
top cog gang
1991 244 LH2.4 M46 360k miles
Old 05-21-2021, 11:27 PM   #531
Cwazywazy
Single jingle
Cwazywazy's Avatar
New torque rods are installed.
I lopped the ends off a pair of stock rods, drilled the holes a tiny bit bigger with a 13/16" bit, then rammed a 7/8-14 tap down 'em.
I used a pair of Rock Krawler RK03524 joints. These are nearly a perfect fit. I had to grind 1mm off the end bit before they would slide nicely into the ears on the axle. They have zerk fittings too. Then I pulled my old torque rods off and transferred the poly bushings over.
I basically guessed on the length setting, something like 5-10mm longer than the stock rods. I tried using my phone to measure the trans and pinion angles but I got different numbers every time. It still has a little bit of a grumble on takeoff, so I think it needs adjusting, but man it's improved. It does transfer more of the weird noises my rear end makes into the car, but that's what the radio's fer.
Old 05-22-2021, 02:57 PM   #532
fatcatbestcat
Professional Hack
fatcatbestcat's Avatar
Needs more D24.
Will you do $14.99 shipped?
-1967 144S
Old 05-22-2021, 04:36 PM   #533
DavePolyakov
How is your oil drain pipe secured to the block? Does it look like you have a metal tube that's going into the hole with a lot of silicone? Just curious if you tapped it or something it's hard to see in the picture.
Old 05-22-2021, 10:12 PM   #534
Cwazywazy
Single jingle
Cwazywazy's Avatar
OH, the pan is what the wagon came with. It's some steel pipe with npt thread on the end that was booger welded into the pan by whoever did the +t on it. It was leaking so I peeled off the orange RTV that was on it, then I ground off what appeared to be Bondo around the weld, then gooped it with JB weld. Not sure if it worked. Before pic:
It's also smashed in at the front from where it hit the subframe.
Old 05-24-2021, 05:00 PM   #535
Alan29
Alan29's Avatar
Think this thread is what I needed to see to get motivated to start thinking about actually doing stuff to my car again. Lovely work.
Signature.
Old 05-24-2021, 08:43 PM   #536
redblockpowered
cone dodging dilettante
redblockpowered's Avatar
Maybe the center bearing support is blowed up?
I sell chips for LH 2.4!
