Old 05-30-2021, 06:10 PM   #1
drj434343
drj434343's Avatar
Default OK to pinch off heater core hoses in a 240?
I've got a leaking heater valve in my 1993 240, and am waiting for parts to come in. The valve leaks externally a bit, but also internally, so heat is partially on all the time.
I would like to just pinch off the heater core hoses in the engine bay just before they connect to the firewall. Is this OK to do without looping? I know in 740/940 the cooling circuit requires circulation, but I think the 240's aren't affected by zero flow, which happens anyway when the valve is closed.
Am I remembering correctly? OK to pinch these off for a week?
drj434343 is offline   Reply With Quote
Old 05-30-2021, 06:21 PM   #2
Considering that is exactly what the heater valve on a 240 does, yes, you can do that safely.
Old 05-30-2021, 06:22 PM   #3
283SD
Yes you can, same as turning the heat off, with out coolant flowing through the heater core. I would replace the pinched hoses as the insides can brake down and cause a hose failure.
Old 05-30-2021, 06:22 PM   #4
PCH
240's engines are the same as 940. Heater valves are different but not in basic function- they do not bypass. Only GM heater valve conversion lets you have a bypass. I think that means you are OK to pinch. When burping the cooling system after it was opened you are always advised to set to max heat, so may be run it first- then pinch.
Old 05-30-2021, 07:15 PM   #5
drj434343
drj434343's Avatar
Thanks everyone, I was 99% sure, but confirmation is always good for something like this.
