View Poll Results: What color for my Titan wheels?
Flat black 7 58.33%
Silver 4 33.33%
White 1 8.33%
Voters: 12. You may not vote on this poll
Old 02-13-2013, 02:21 AM   #501
Roy 940
Some pics of my head (not finished yet) :
And from the runners side (cylinder 1-2-3-4) :
And from the CC side :
More to come soon...
project Blue is Better
http://forums.turbobricks.com/showthread.php?t=247082
Roy 940 is offline   Reply With Quote
Old 02-13-2013, 08:04 AM   #502
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
What tools you're using ?
Old 02-13-2013, 08:26 AM   #503
redbaronmulisha
should the water channels be plugged like that? sorry for novice question but I always thought the channels should be as open as possible
1997 945 turbo - 20psi of LOL
2002 nissan cube -
redbaronmulisha is offline   Reply With Quote
Old 02-13-2013, 08:29 AM   #504
poulrais
poulrais's Avatar
1990, Volvo 740 16v +T
Old 02-13-2013, 08:57 AM   #505
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
What?
Old 02-13-2013, 09:23 AM   #506
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
I think he means that area on the heads surface that looks like theres a clogged waterport, but its just dirt from the open port in the block and gasket...
Old 02-13-2013, 07:50 PM   #507
Roy 940
The runners are not equal now, I've to correct it, and to sandblast the intake runners.
I'll post pics of the tools I've used soon!
Old 02-14-2013, 08:37 AM   #508
Roy 940
And after some calculations, my new CR will be around 9.3:1!
And my phenolic spacers are here!
Old 02-14-2013, 11:14 AM   #509
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
isnt that pretty hi for a turbo engine?
Old 02-14-2013, 11:25 AM   #510
doucheNozzle
doucheNozzle's Avatar
Meh
'93 944 T - #TrophyVo
'00 XC70 SE - Slow
'11 XC90 V8 - Torque Monster
Old 02-14-2013, 11:55 AM   #511
Roy 940
It'll be enough I think! That's why I'm thinking about decreasing a bit the boost also (from 1.2 bar to 1.0 bar) => 17psi to 14 psi...
Old 02-15-2013, 08:06 AM   #512
Roy 940
Intake runners are finished! I've to sandblast it, but that's all!
This afternoon I'll start with the exhaust side...
Old 02-16-2013, 02:48 PM   #513
Roy 940
Old 02-28-2013, 04:48 PM   #514
Roy 940
Ok guys, here are the pics of my head, from exhaust side...:
The bowls :
The short radius :
And the intake runners (not sandblasted yet...) :
And a general view :
Job to be done now :
-sandblasted the intake runners
-lap the valve
-match the valve springs
-install it in the car!
Old 02-28-2013, 05:42 PM   #515
doucheNozzle
What valve springs are you going to put in?
Old 02-28-2013, 05:59 PM   #516
Roy 940
Stock springs + shims...
Old 02-28-2013, 06:09 PM   #517
doucheNozzle
Now's the time to upgrade!
Old 02-28-2013, 06:15 PM   #518
Roy 940
I'm running the stock valve, and I don't rev it more then 6500 RPM... I think harder springs are not needed!
Old 03-01-2013, 04:21 AM   #519
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
[QUOTE=Roy 940;4507455 I don't rev it more then 6500 RPM... [/QUOTE]
In Germany we have a word for this... Mushi!! :D
Old 03-01-2013, 04:30 AM   #520
Mushi!! :D
Translation:
Old 03-01-2013, 01:06 PM   #521
Roy 940
You're really mad...
Old 03-02-2013, 08:47 AM   #522
Roy 940
Any comment about my head?
Old 03-02-2013, 02:14 PM   #523
HansW
HansW's Avatar
Mating face, my friend, -- not good enough for MLs if it is to last.
You'd need to get that head decked/ planed--
Look at my head 2 pages back --That just about did it with Hylomar.
940 classic Cd 1997
B230FT / M90L
530 head planed, KG 2T cam
Head gasket: Elring standard (Mls 0.35 was too tight, -- piston- head contact),
1041 axle 3.74, M90
15G at 0,85 bar
3" turbo back JT-superflow
3" Amm. + 42lbs injectors
STONI chips in 984 ecu and 167 EZK
Bosch WR5 DC+ (+15)
HansW is offline   Reply With Quote
Old 03-02-2013, 07:40 PM   #524
Roy 940
For sure my friend! It's not finished yet! The intake runners'll be sandblasted, I plan to shave it something like 0.5/0.6mm, + some other job to finish...
Old 03-05-2013, 08:18 AM   #525
Roy 940
Intake runners are sandblasted now!
