View Poll Results: What color for my Titan wheels?
Flat black 7 58.33%
Silver 4 33.33%
White 1 8.33%
Voters: 12. You may not vote on this poll
Old 07-25-2013, 04:48 PM   #651
Roy 940
Originally Posted by MadDog_945 View Post
i would say AMM is maxing out and does some trouble to LH...
I have the same issue...
Is it possible to max out the 012 AMM so easy?
project Blue is Better
http://forums.turbobricks.com/showthread.php?t=247082
Roy 940 is offline   Reply With Quote
Old 07-26-2013, 03:36 AM   #652
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Yes... with 16v absolutely no problem.. and with your mods... ...just before the redline... makes sense..
Old 07-26-2013, 06:18 AM   #653
Roy 940
When I was running at 1.3 bar (19PSI) boost, the issue was from 5K RPM... I think it's very soon...
Old 07-26-2013, 05:43 PM   #654
Roy 940
Other then that, my AFR is 11.5/11.7 'till 6000+ RPM now! So my car pulls rock solid from 4000 to the redline now!
Huge thanks to TLAO for his very good help and advices!
Old 08-14-2013, 06:07 PM   #655
HansW
HansW's Avatar
Hi Alex
I think that Water-oil heat exchanger is not very efficient, -- if the engine is just warm, I get better power and less pinging, than if the engine is hot.
So my plan is to change to an air-oil cooler. I am in the process of collecting all the parts, I will be using a 24 row Mocal cooler, which I got for a very good price on EBAY in combination with my thermostat sandwich plate. This should keep the oil temps between 80 and 90 deg.
I,ll post more when I am at it.
cheers, Hans
940 classic Cd 1997
B230FT / M90L
530 head planed, KG 2T cam
Head gasket: Elring standard (Mls 0.35 was too tight, -- piston- head contact),
1041 axle 3.74, M90
15G at 0,85 bar
3" turbo back JT-superflow
3" Amm. + 42lbs injectors
STONI chips in 984 ecu and 167 EZK
Bosch WR5 DC+ (+15)
HansW is offline   Reply With Quote
Old 08-15-2013, 01:34 AM   #656
Roy 940
Hi Hans,
Thanks for the tricks! Please let me know your new oil temp with your new cooling system
Cheers, Alex.
Old 08-20-2013, 07:43 AM   #657
HansW
HansW's Avatar
hi Alex
A few pics from the cooler; works great.
Old 08-20-2013, 04:27 PM   #658
HansW
HansW's Avatar
it seems to make better power when hot, as the pinging starts later, -- the ignition doesn't have to retard as much as itused to when the engine was hot.
Old 08-20-2013, 06:38 PM   #659
Roy 940
Interesting! Your car continue to ping? Even with Stoni's chips?
Old 08-20-2013, 07:01 PM   #660
HansW
HansW's Avatar
The ping when accelerating from low refs never went away. Not with Mike's not with Stoni's or the bosch chips. All 940' here have it. It is just a quick ping ping, and that is it, but you feel the power been taken away somehow. It does not come on the other side of 3500 refs.
Old 08-23-2013, 07:25 PM   #661
Roy 940
You're not lucky about the pinging...
Old 08-24-2013, 12:27 AM   #662
Woles
Good day to you.
I want to ask you about http://www.ebay.com/itm/Kinugawa-Bil...80609566504%26 . Is it good? As you have realized takoyzhe.
Woles is offline   Reply With Quote
Old 08-24-2013, 08:01 AM   #663
mocambique-amazone
Hi Hans, in my opinion you should modify the lower bracket of your mocal. It is far too stiff, the mocal expands amazingly when getting hot. The lower part is fixed better in rubber mountings or with washers and able to slide while expanding. The upper are ok.
cheers Kay
Old 08-24-2013, 12:30 PM   #664
HansW
HansW's Avatar
Hmm--no problem if it expands upwards, -- the top brackets have enough give, and sidewise, -- the bottom ones have give on the lower radiator bracket -- So up to 2,-3 mm heat expansion, no problem sidewise. I drilled the holes on one side to 6,5 mm and use washers, not tidying the nuts too much, just to be on the safe side.
Old 08-24-2013, 02:45 PM   #665
mocambique-amazone
Hi Hans, I allready imagened that you will have done it in a proper way
Old 08-24-2013, 05:40 PM   #666
Roy 940
Originally Posted by Woles View Post
Good day to you.
Hi!
Unfortunately, this link is not working...so I can't give you any feedback about it... Sorry!
Old 08-24-2013, 05:45 PM   #667
Woles
http://www.ebay.com/itm/Kinugawa-Bil...-/290951450737
Old 08-24-2013, 05:48 PM   #668
Roy 940
Other then that, I've ordered this :
http://shop.klracing.se/sv/artiklar/...la-utblas.html
I mounted it wednesday, as soon as it was here... What I can say is :
It looks very good, shinny finish. But, even with the 3" inlet pipe, in the muffler it's 2.5"... The sound is ugly , with a huge drone @ 3000 RPM, and my car lost a lot of power past 4500 RPM...
So, I'm back to my previous real 3" JT muffler, and my car (and my ears) are happy now!
If you're tempted to buy this KL crap, stay away for it! Even with this low price, it's still too expensive for what it is...
Old 08-24-2013, 05:49 PM   #669
Roy 940
I can't access to your link from here... Can you find an other link?
Old 08-24-2013, 05:55 PM   #670
HansW
HansW's Avatar
All what it is, is a actuator where you can change the spring inside, -- bit pricey considering other boost controllers.
JT rocks!!!!
Old 08-24-2013, 06:10 PM   #671
Roy 940
Ah ok!
I'm using this :
http://www.forgemotorsport.co.uk/con...duct=FMAC95932
And as you said, JT rocks!!!
Old 08-25-2013, 02:17 AM   #672
Woles
Okay, I understand you.
Old 08-25-2013, 06:22 PM   #673
Roy 940
You're searching for an adjustable WG actuator?
Old 08-25-2013, 07:12 PM   #674
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Hi,
I would buy it if youre up to
Old 08-25-2013, 07:14 PM   #675
Roy 940
Hi,
Really???
