Old 04-18-2014, 11:23 AM   #1
Inside_the_box
Default 76 242 gas cap
When I got my 76, it didn't have a gas cap so I am not really sure what the cap looks like or how it screws into the fill tube. I think I am missing a part or something because my fill tube is a smooth aluminum tube with no apparent means of screwing in a gas cap. Does anyone have a picture or a parts diagram? Are 76 gas caps different then later cars?
Inside_the_box is offline   Reply With Quote
Old 04-18-2014, 11:35 AM   #2
No just go to Kragen and buy one.
how psi stock cna sprout?
Old 04-18-2014, 01:00 PM   #3
Inside_the_box
There is nothing to screw into, it is just a smooth aluminum tube.
Old 04-18-2014, 01:36 PM   #4
The Librarian
Late 140/160 and early 240/260's used a different style gas cap. It sounds like your tank and fill tube have been updated because you should have notches in the end of the tube to accept the cap.
If your fill tube looks like this, you need the screw on cap.
Old 04-18-2014, 01:47 PM   #5
Inside_the_box
That's it hiperauto, I am missing the cap and the little circular connector pictured in the first photo. Now I know the parts I need, anyone know where to find them?
Old 04-18-2014, 03:59 PM   #6
The Librarian
I have the cap and filler neck end piece. There are a couple of more parts involved though. There are 2 seals (#18 & 21) and the leaded fuel restrictor (#20) as well. The resitrictor isn't necessary, but you'll still need at least 1 seal which is no longer available from Volvo.
Old 04-18-2014, 04:05 PM   #7
Jack
junkman
Jack's Avatar
I have a filler neck for stock cap
I love you even more Jack.
